-   General HD (720 / 1080) Acquisition (https://www.dvinfo.net/forum/general-hd-720-1080-acquisition/)
-   -   Alternative to BlackMagic shuttle (https://www.dvinfo.net/forum/general-hd-720-1080-acquisition/536753-alternative-blackmagic-shuttle.html)
David Pakman May 13th, 2019 07:18 AM
If this isn't the right subforum please feel free to move, wasn't 100% sure.
I currently use a blackmagic shuttle to get my audio and video into a computer, where I use OBS to record interviews where the guest is on skype
The signal flow is:
Audio & video from camera => blackmagic shuttle => HDMI into my computer => OBS, where it is added to the skype guest's audio and video
The problem is that the shuttle does not work as a skype webcam. If i have OBS open, the guest CAN hear my audio, but my camera is not recognized by skype since blackmagic isn't supported as a skype webcam./
My question is very simple: What devices could I put in place of the blackmagic shuttle that would do everything i'm currently doing while in ADDITION allowing me to send my video to the guest so that they can see me?
Brad Kraus May 13th, 2019 08:42 AM
Re: Alternative to BlackMagic shuttle
we use these:
https://www.bhphotovideo.com/c/product/1318044-REG/blackmagic_design_bdlkwebptr_web_presenter.html/BI/2855/KBID/3801
they are made for exactly this purpose. We run all of our video (cameras, power point presentaiong onm a seperate PC, etc.) through a switcher and into the web presenter, but the end result is pretty much the same as what you are going for.
We also have a couple Vaddio bridges that we use as well, but to be honest the BMD Web Presenter does a great job at 1/3 the price.
Brad Kraus May 13th, 2019 09:43 AM
duplicate post
David Pakman May 13th, 2019 11:12 AM
Originally Posted by Brad Kraus (Post 1950495)
we use these:
very interesting, and if im just recording video from a local camera with this device, will the quality be just as high as with the shuttle? ie, no degradation of any kind?
Brad Kraus May 13th, 2019 11:48 AM
The Web Presenter itself doesn't record so you could loop either an SDI or HDMI signal out of it into your Shuttle. You should see recording quality identical to what you are seeing now.
David Pakman May 13th, 2019 12:30 PM
sorry i realize my question wasn't clear. currently i use the shuttle to get the video from my camera, via HDMI, into the shuttle, and out to the computer with USB3. Am i correct that i can REPLACE the shuttle with this device in the same way as the mechanism to get the video into the computer for recording in OBS?
Brad Kraus May 13th, 2019 01:35 PM
Ah, now I see. Yes, that will work very well. The Web Presenter will capture incoming video and output it via USB3 to the PC where it can be used in a Skype meeting or however else you like. Hope this helps!
David Pakman May 15th, 2019 07:23 AM
one other question on this: it looks like it is limited to 720p. I believe that the shuttle is handling much higher quality video. is 720p the limit for the use as a WEBCAM specifically, or even in OBS i won't be able to record higher than 720p video with this device? thanks!
Brad Kraus May 30th, 2019 12:40 PM
Sorry for the late reply. I missed this somehow. The video on the Web Presenter is indeed limited to 720p, regardless of how it is used. it is a limitation of the device and its original intended purpose, which is streaming video to the web. I had forgotten about this limitation - sorry for getting your hopes up!
Jeff Pulera May 30th, 2019 02:00 PM
Perhaps consider using NDI which is a very popular video over IP protocol from Newtek.
You get a converter box from either Newtek or a few different third-parties which converts HDMI or SDI sources to NDI, which is then available to all devices on your local network.
OBS, WireCast, vMix, LiveStream, WireCast can all accept NDI sources now, with full HD quality as if coming from a capture card. As for apps requiring a "web cam" source, run the free NDI VIRTUAL INPUT app which then makes any available NDI source appear as a web cam to any software looking for a web cam source.
https://www.newtek.com/ndi/tools/
