-   General HD (720 / 1080) Acquisition (https://www.dvinfo.net/forum/general-hd-720-1080-acquisition/)
-   -   RG59 vs RG6 coax for SDI (https://www.dvinfo.net/forum/general-hd-720-1080-acquisition/518001-rg59-vs-rg6-coax-sdi.html)
Adam Grunseth July 28th, 2013 04:48 PM
Hi everyone!
I am putting together a multi-camera live switched setup. I know that RG6 coax is best for digital signals, especially over long runs.
My questions is how long of cable runs could I realistically expect to be able to pull off with RG59 when doing 1080i SDI transmission.
Buba Kastorski July 30th, 2013 08:23 AM
Re: RG59 vs RG6 coax for SDI
some good info here
Jacques Mersereau July 30th, 2013 10:51 AM
We use both Canare RG59 and Belden 1694 cable (RG59) for our HD-SDI wiring infrastructure.
I've had runs over 200 ft and not had any problems.
I believe the spec is 300 ft. Need longer, you can purchase 'balens' that turn the signal into optical and can go over 6 kilometers on glass fiber.
RG6 is thicker, which is usually considered better, but as long as the cable is spec'd to work with HDSDI, I think you're good to go over 200 ft.
