Re: Need to buy a camera for a sportscenter
The Sony HC1 is a first generation consumer HD camcorder. If you want something like the HC1 but with a better picture quality, then consider the Sony HDR PJ710V or CX760V, the Canon HF G10 or the Panasonic HC-X900K. Even the Canon HF M500 and the Panasonic HC-V700 which sell for around $500 perform significantly better than the HC1. These tiny consumer camcorders all yield excellent images in adequate lighting and are quite convenient to use. |
[QUOTE=Nate Haustein;1740439
I would perhaps step away from the XF100 (and definitely the 105) as you don't really need a "broadcast" codec for what you're doing, and your computer might struggle with the MXF files.[/QUOTE] MXF files are much easier to handle and edit than AVCHD, so not sure where you get that info from. |
| All times are GMT -6. The time now is 06:43 PM. |
