-   General HD (720 / 1080) Acquisition (https://www.dvinfo.net/forum/general-hd-720-1080-acquisition/)
-   -   HDV 25mbps Im confused (https://www.dvinfo.net/forum/general-hd-720-1080-acquisition/36296-hdv-25mbps-im-confused.html)
Bob Horwell December 12th, 2004 05:28 PM
Hi it's my first posting.
HDV transfers at 25mbps, so what's the benefits over DV? same size CCD's as say DVX100 and same colorspace. More lines on HDV= higher compression? It's 25f (interlaced) what's the benefit of this, uncompress to de-interlace, loose 1080i. I'm really confused about the benefits of HDV. Surely we want 100mbps to make it worth while, to call it Hi-Def. Is it Sony jargon confusing pro-sumers into thinking they can shoot HD?
Hope some of you can clear this up for me.
Barry Green December 12th, 2004 05:37 PM
Both DV and HDV use 25mbps encoding. However, HDV uses MPEG-2, which has the potential of being much more efficient than DV encoding. DV encodes every frame as a discrete unit, whereas MPEG-2 in HDV approaches it differently, encoding entire groups of 15 frames in one block, by encoding only one frame discretely, and encoding the following 14 frames as variations/differences from the first frame in the group.
MPEG-2 has its share of problems, certainly -- but when you watch the footage from the FX1, in interlaced high-def mode, on a high-def monitor, it definitely looks like high-def. Not quite like a VariCam or CineAlta, but then again it shouldn't. But it's unquestionably high-def footage, much higher resolution than DV is capable of.
It's not "Sony jargon", since HDV as a format is supported/sponsored by/agreed to by Canon, Sony, JVC, and Sharp.
After spending several days with the FX1, my initial optimism about HDV has turned much more pessimistic -- I think I'd rather (much rather) see a version of DVCPRO-HD implemented in a consumer-level camera, such as Panasonic has teased about.
But to say that HDV isn't HD is to deny the evidence of one's own eyeballs. Look at the footage on a 1080i HD monitor... it's high-definition. It's not raw 1920x1080, but it certainly is an implementation of high-def.
Bob Horwell December 12th, 2004 05:45 PM
Thanks Barry. Wow that was quick!! So is the 25f interlaced? if so in your opinion does it look anyhting like the 25p of the XL2? I'm really keen to have a look at the new HDV in feb and i have to agree, if panny can knock out the DVCPRO HD, well happy days :-)
Laszlo Bodo December 12th, 2004 05:51 PM
The 25f isn't interlaced. The 50i original footage converted in-camera to 25p isn't interlaced any more.
Barry Green December 13th, 2004 01:23 AM
No experience with Cineframe 25. It should be the same thing as Cineframe 30, which is recorded on the tape as interlaced, but looks as if it was captured progressively.
There is no such thing as progressive 1080 footage in HDV. It's all interlaced. However, there's no such thing as Progressive DV, and that didn't stop Canon and Panasonic from implementing it anyway. So in that same vein, Cineframe 25 should look like lower-resolution progressive footage, in the same way as "frame mode" on the Panasonic and Canon cameras looks like actual progressive scan. Each frame is derived from a single point in time, vs. interlaced where they're derived from two different points in time.
In true progressive scan you get the entire frame captured at once, and (at least on NTSC and PAL systems) you can get higher resolution than you can in interlaced.
In 1080 HDV, there is currently no progressive scan, so you have to de-interlace and/or interpolate one field to create the other field from the same moment in time, or perform other types of processes to simulate the look. In-camera Cineframe 30 looks pretty good, it's lower in resolution than raw 1080/60i but still higher-res than DV, of course. I haven't studied the still shots and res charts enough yet to figure out just how much of an impact on resolution it has, and in fact it's very difficult to come to a conclusion on that because what works for a still frame may not work for a moving frame, most especially in an MPEG-2 system like HDV. A still-shot like a resolution chart may show basically full resolution, but a moving shot may drop that to half-resolution, compounded further by MPEG motion compression artifacts... it's tough to answer all the questions, because sometimes you don't even think about ways to test for things until you've already sent the camera back! But I guess that's all part of being out here early on the "bleeding edge" of HDV/1080i.
Toke Lahti December 13th, 2004 10:51 AM
<<<-- Originally posted by Barry Green : No experience with Cineframe 25. It should be the same thing as Cineframe 30, which is recorded on the tape as interlaced, but looks as if it was captured progressively. -->>>
Actually all tape formats are recorded in fields.
That's why sony calls progressive formats PsF (progressive segmented frames).
Is it same with xdcam's pd-disks, anyone?
Barry Green December 13th, 2004 01:46 PM
24PsF was a modification of a 50i tape mechanism... but I don't believe that all progressive is recorded as interlaced... I'm pretty sure the HDV 720/30p is recorded as pure progressive, and DVCPRO-HD is recorded as pure progressive... unless I'm wrong...
Dylan Pank December 13th, 2004 06:56 PM
<<<-- Originally posted by Toke Lahti :Actually all tape formats are recorded in fields.
Actually I thought with digital, it was the other way around - that all video is really progressive, but the CCDs still scan interlaced, and those two fields are printed as one prgressive frame, which was then turned into two fields when it becomes and analogue signal to go to the TV.
Analogue was recorded as fields because the second field followed the first along the linear signal.
Have I been wrong about this all this time?
Graeme Nattress December 13th, 2004 08:18 PM
Digital video started as a digital representation of an analogue signal, so digital video can be interlaced because the analogue it was recording is interlaced, or it can be progressive if the analogue signal was progressive.
For progressive to be truely progressive, a whole frame must be made in one instant of time, that instant governed by the frame rate and the shutter.
With interlaced video, for each frame, two instants are recorded, but are stored together combined as a frame which gives many benefits for early television as interlacing is really just analogue compression. For PAL, 50i, you get most of the smoothness and most of the resolution of 50p but in half of the bandwidth, and, that was necessary with early TVs as the electron bean couldn't scan fast enough to make one whole picture in 1/50th second, but it could make a half picture every 1/50th a second.
So no, all video is not really progressive, and digital or analogue really have nothing to do with it.
However, the issue with the FX1 is whether the 25cf mode uses a "good" de-interlacer or not. If it's anything like the CF24 mode, I'd be doing the de-interlacing in sofware where I can properly control it. In FCP, my Film Effects, www.nattress.com did a far better job of making a nice film effect than the CF24 mode by starting with normal 60i footage. If anyone can put up a 50i / CF24 comparison I'd really like to see it!
Graeme
Robert Silvers December 16th, 2004 03:27 PM
HDTV broadcasts in the US are 20mbps. HDV is more bits per second than the HD broadcast standard. But sure, you *want* to capture and edit at a higher quality than distribution, so it would be nice if it were 50mbps. In fact, Sony band-limits their studio cameras to 1440x1080 (and the FX1) because they found that 20mbps is not enough for 1920x1080 without overloading the mpeg encoder.
Bob Horwell December 16th, 2004 04:42 PM
This has turned out to be very educational, thank you so much for the input guys. I suppose what i'm trying to work out is weather i should sell my DVX100 and go for the new HDV from Sony. I just don't know if it's oranges and apples, as we say in blighty.
Is the HDV really a step forward from the 25p DV on the panny'?
Robert Silvers December 16th, 2004 04:59 PM
Well the Sony is not progressive. If you are asking 'does the Sony image clearly look better' then the answer is "Yes, much better."
But if you need 25p to go to 24fps film or some other specific use, then you may want to wait for the second generation which can do some progressive formats.
I am just borrowing the Sony FX1 and won't sell my Canon Optura Xi right now because I could never get any money for it since I broke the flip out screen and also I bought it less than a year ago and don't use video much. But it is a way-better image. Since your camera is more high-end you should sell it before everyone realizes how awesome the new Sony is. There are still MANY people who have not realized that their VX2100s are worthless now.
Yes, the Sony FX1 is the real deal and not an incomplete or poor implementation of 1080i. The camera is incomplete only in that it does not offer 24p, 25p, and 30p and perhaps the next version will or another brand might.
Barry Green December 16th, 2004 05:01 PM
If you're staying in high-def, and exhibiting your work on a high-def display, and you like the "looking through a window" look of interlaced 1080i HD, then yes it's a big step up.
If you're going to be distributing on DVD, no, the FX1 is a step backwards for that.
Robert Silvers December 16th, 2004 05:13 PM
But everyone might want to think of the future. While it won't look better on DVD, DVD will be obsolete in 2 years.
If you shoot with the FX1 you can convert it to HD-DVD or Blu-Ray later. Also you can distribute on DVD now with WM9 or other compression.
I shot my wedding in 720P even though I had no way to edit or play it. I still need to get the tapes (Panasonic) onto a hard drive but don't want to spend the money to covert it until it is cheaper. Now if the Sony was out then, I would be editing it already because of the 1394 interface.
Barry Green December 16th, 2004 06:11 PM
Some valid points, which is why I acknowledge that if you want to have it in high-def, the Sony is a step forward, a big step forward.
Whoa. Got to disagree. The consumer electronics industry started pushing HDTV on us 20 years ago, and SDTV has clung on so far, and still accounts for about 97% of the televisions in America, and 99.9999% of the TV's in Europe. It took VHS a long, long time to succumb. I think it's reasonable to expect DVD to be with us for several years, maybe as many as 8 or 10.
Just because a new format may become available, it won't have market saturation overnight! DVD is the fastest-adopted format launch in consumer electronics history, and it took six years for it to penetrate 50% of American households... Six years. And people clung to their VHS players that whole time. And that's just half the households. AND, all those people already owned a TV!
Now compare that to HD-DVD... Something like 97% of American households have no ability to display an HDTV signal. The most optimistic figures I've ever heard are that HDTV is in 10% of American households, a figure I highly doubt. So who will be buying HD-DVD players, what will they be playing them on, and will they really obsolete DVD in just two years? Or five? Or 8?
The most optimistic figure I've seen yet places 50% market penetration of HDTV at the end of 2008. Four years from now. It might take HD-DVD four or five years to become a significant presence in the world's households (other than just among "early adopters"). And every one of those households will still have a regular DVD player.
Standard-def DVD will be a viable distribution format for many years to come.
Robert Silvers December 16th, 2004 06:17 PM
Let me rephrase that to say you will need to be creating content for HD-DVD or BluRay starting next year, but yes -- also putting stuff on DVDs for compatibility.
But do you really want to ONLY be putting stuff out on DVDs in 2 years?
Robert Silvers December 16th, 2004 06:25 PM
Then again, I know a wedding videographer still using an AG465 S-VHS camera. His web page describes it as 'state of the art industrial video equipment.'
Ken Hodson December 16th, 2004 06:52 PM
"HDV approaches it differently, encoding entire groups of 15 frames in one block, by encoding only one frame discretely, and encoding the following 14 frames as variations/differences from the first frame in the group."
Is that how it works on the Sony? The HD10 uses a 6 frame GOP in 30p or a 12 frame GOP when shooting 60p.
Barry "If you're going to be distributing on DVD, no, the FX1 is a step backwards for that."
Why do you say that? It has been my experience that Downsampling from a higher rez source (eg. film/HD) will always give a better final product than a SD souced one, especially if it is DV based.
Barry Green December 16th, 2004 08:07 PM
As a producer, I want to be putting my product on whatever format will sell, and that which will reach the customer. It will be many years before HD-DVD/blu-ray will be much more than a niche market, whereas DVD is a worldwide standard.
It's like the conversion to digital projection in theaters -- people have been talking about it, predicting it, trying to force it, yet it remains completely non-viable. If you want to release a film on this planet, to show in theaters, it has to be on 35mm film. 35mm film will play in basically every theater in the world, whereas digital projection as a distribution medium occupies -- what, 1/10 of 1% of the theaters out there? People may love the idea of digital projection, but it is not reality, and doesn't look to become reality any time soon.
So it will be with HD-DVD and blu-ray... may be promising new technology, but it's not a realistic distribution medium yet, nor will it be a substantial distribution medium for years to come.
Barry Green December 16th, 2004 08:13 PM
Yes, the Sony uses much longer GOP's, 15 frames at a time. It's not a Sony vs. JVC thing, it's part of the HDV standard, so any camera that employs 1080i HDV will use a GOP of 15, any camera that employs HDV 720/30P will use a GOP of 6.
I base it on direct observation, having shot with the three cameras side-by-side, all three mounted on the same tripod shooting the same scene under the same lighting conditions, then split-screening the footage and making DVD's of the footage.
I then watched that footage on a computer DVD player, on a conventional interlaced television, and finally on a 10' screen projected by an LCD projector using component inputs from the DVD player.
I've posted a number of pictures and commentary on another site, and I've talked with Chris about publishing the full camera comparison review article here on DVInfo.
In my observation, there is no benefit to added HDV resolution when the image is resized to DVD resolution, yet the HDV camera still exhibits much less light sensitivity (a good two to three stops slower than the DVX, about 1 to 1.5 stops slower than an XL2) with less latitude as well. You get no additional benefit of image sharpness, but you take steps backward in low light performance, overall sensitivity, filmlike motion rendition, audio connectivity, etc. The FX1 can put out a great picture on an interlaced HD 1080i monitor, that's for sure... but by the time you make a DVD out of it, you could make a better-looking DVD from the DVX or XL2.
If your intended distribution medium is HD broadcast, or HD-DVD to the portion of the market who can play that, or on a private display system (such as a corporation's own HDTV system in their lobby, etc) then the FX1 makes wonderful high-res footage. But if it's for distribution to the mass market through DVD, the DVX and XL2 do a better job.
Ken Hodson December 16th, 2004 09:41 PM
Interesting. That is not my experience at all. My one worry was that HDV wouldn't help when converted to standard DVD, but this is not proven to be the case. The higher resolution has allowed much more detail even when downsampled as well as eliminating aliasing that is so obvious from DV cams.
If increased resolution wasn't a benefit than film put on DVD wouldn't look much better than those shot on SD. This clearly isn't the case.
