1080/60i to 720/24p conversion
We all know about magic bullet, etc. Should it not be possible to take a 1080/60i clip from the FX1, and convert it to 1080/24p with inverse telecine?
Now there would be some interlacing artifacts if the frames were simply constructed straight, so a small amount of gaussian blur and a down-rez to 720p ought to more than make up for that. So shouldn't it be possible to get awesome 720/24p footage out of this thing in post? Also does anyone know about the cinemotion option? Is it similar to Canon's frame mode? |
Hmmm...Wouldn't you want 1080 24p? That's better.
I'm sure you could convert it to 24p, then down-rez it to 720p. hwm |
1080/24p would of course be ideal, but when you go from 60i to 24p you lose a little bit of sharpness. My thought was that that would be made up for by downrezing to 720p.
1080/24P should be entirely possible, using something like Magic Bullet or DVFilm Maker. It won't be quite the same as if it'd been true 24P in the first place, but -- heck, it'll probably be pretty darn good!
I wonder if this is exactly what the FX1's fake 24p mode does.
I don't think it has a "fake" 24p, at least not that I've heard of.
hwm |
Just a guess doesn't the DVX flag the frames it doesn't use. Because I thought it still records at 30 frames and then when you go into your editor, the editing system sees those flags and pulls those frames out.
So I'm wondering if the frame mode in the Sony will do the same. It would flag the frames and then in FCP HD (HDV) remove those frames. |
It does have a "fake" 24P mode, called CineFrame 24 (and also has a "fake" 30P mode). But to be truthful, we shouldn't necessarily use "fake" to describe it until we see how well it performs. If it looks fantastic, why cripple it with the word "fake" regardless of how it accomplishes the goal?
The DVX flags the frames because it actually records 24 distinct frames per second, then adds split frames to round it out to 60 fields. The Sony works backwards from that. It can't shoot 24 frames per second, it only shoots 60 fields, so it has to somehow in-camera try to interpolate/blend 60 fields into 24 frames. So it's actually the opposite of what the DVX does. Doesn't mean it won't look good (although I guess the potential exists for it to look awful, but we'll see). It won't be true 24P by any stretch, but programs like DVFilm's Maker software can do a pretty good job of simulating the 24P look, so maybe the Sony does a good job too... |
Yeah Barry, there's pretty much one only one way (at least that I'm aware of) of taking 60i to 24p:
60i: 1A 1B 2A 2B 3A 3B 4A 4B 5A 5B becomes 24p: 1A+1B, 2B+3A, 3B+4A, 5A+5B OR some variation thereof, But combining fields is problematic because the field actually occurs 1/60th of a second later than the prior field, thereby introducing combing during motion. So you have to apply some kind of blurring to eliminate the combing, reducing your resolution. My guess is that it is not reduced in resolution much worse than to 720p. But still then it's not temporally perfect, since the temporal transition between the 1st and 2nd, and between the 3rd and 4th frames, is twice what it is between the 2nd and 3rd, and between the 4th and 5th frames. But it's little worse, if at all, than watching 24p footage telecined to 60i. My guess is that this is what the FX1 does, and then it probably records the resulting footage in plain old 3:2 60i which Vegas hopefully will be able to ivtc for you. If I'm right, Cinelook 24 won't be so bad. I didn't mean to disparage it when I said fake. :) It's fake like cubic zirconias are fake - still pretty good, but you won't impress the most discerning eyes. BTW, unless I'm wrong, nothing (Magic Bullet, etc.) is really going to be any better. Well, true 24p would be. |
Converting 1080i to 24P
There is some speculation that the Sony FX1 HDV camcorder will not provide true 24P, in other words the CCD will not be sampled at 24 fps.
The latest release of DVFilm Maker (2.00f) for Windows (http://dvfilm.com/maker) has a slight modification to accept frame sizes up to 1920 x 1080, so it could be used to convert 1080i to 1080-24P, or to remove either a 3:2 or 2:3:3:2 pulldown from 1080i. The clips would first have to be converted to uncompressed AVI or Quicktime. This would yield better results than the camera's built-in 24P mode assuming that it is getting 24P by dropping frames from a 30P acquisition, or dropping fields from a 60i acquisition. |
Marcus,
Thanks for posting about this, as many are interested in knowing. heath |
My Film Effects and Standards Conversion for FCP will also deal quite happily with 1080i60 to 24p, either keeping it 1080 or converting down to 720p.
Graeme |
"This would yield better results than the camera's built-in 24P mode assuming that it is getting 24P by dropping frames from a 30P acquisition, or dropping fields from a 60i acquisition."
Except dropping fields is exactly how any 60i->24p conversion happens, so I think there's no reason to believe Sony's simulated 24p would be any worse than any other software's conversion. I'm not aware of any other ways of doing it. |
Yes, there are much better ways of doing it. Maker uses
motion-weighted resampling methods. |
Will there be an advantage to having the 50i version of the FX1 for 24P conversions. Basically, does 50i convert to 24P (via 25P) better than 60i or is there no real difference?
50i will be better than 60i. It's easier to convert (and hence you get better results) 50i to 25p than 60i to 24p. Also, you're therefore shooting using the full 25mbps and keeping most of it for your 25fps, rather than throwing some of it away by recording those 5 extra frames per second for the 60i, that you'd need to remove some how.
Graeme |
"Maker uses motion-weighted resampling methods."
What software is that? |
DVFilm Maker (http://dvfilm.com/maker)
DVFilm Atlantis (http://dvfilm.com/atlantis) also uses motion-weighted resampling to convert PAL to NTSC and NTSC to PAL. The techinique was developed about six years ago for our video to film transfer service. Both applications run on Windows and Mac and can be used with virtually any editing system. |
The FX-1's CineFrame 24 made very well be real 24p, if it's done with the camera's SD mode (as suggested by another member in a different thread). Or is it only the pro model that can shoot in SD?
UPDATE: "CineFrame24 and 30 Mode. This is an attempt by Sony to cater to those independent filmmakers seeking the "film look" with a 24 frames-per-second progressive scan shooting mode. Although the HDR-FX1 does not have a true 24P or 30P filming mode, the CineFrame24 and Cineframe30 modes replicate many of the motion artifacts and the "look" of 24P and 30P, respectively. The CineFrame 24P mode on the HDR-FX1 is enhanced over the 24P effect mode that some users will remember from Sony's DCR-PC350 because it does a 2:3:2:3 pull-down instead of a 2:3:3:2 pull down. When I tested the HDR-FX1's Cineframe24 mode, I did not see the same jerkyness that I found on the DCR-PC350. That is, although any 24P mode will have a certain jitter to it, the DCR-PC350 had an odd "beat" to its jitter that was unnatural. I wasn't able to identify any such "beat" on the HDR-FX1, and the footage looked noticeably better. I think that for the majority of users, the CineFrame24 mode will do a fine job of giving you that 24-frames progressive scan look, while still of course delivering HD resolution -- something the Panasonic AG-DVX100 and the Canon XL2 can't do!" - http://www.camcorderinfo.com/content/Sony-HDR-FX1-First-Impression-Camcorder-Review.htm |
<<<-- Originally posted by Peter Moore : 1080/24p would of course be ideal, but when you go from 60i to 24p you lose a little bit of sharpness. My thought was that that would be made up for by downrezing to 720p. -->>>
I'm curious. How would decreasing the res compensate for a lack of sharpness? |
Lack of resolution and lack of sharpness are essentially the same thing. Downrezzing will not necessarily make the picture look more sharp, but my point is that a slightly unsharpened 1080p (from inverse telecine) might be about equivalent to the sharpness of 720p, so I might as well deliver footage in that latter format since it's half the bandwidth and would look perfect on 720p fixed pixel displays and projectors (whereas virtually no one has 1080p display capability).
Okay. That makes sense.
