HD on a budget?
Hi All
Looking to start moving my screen plays forward. (Shane Meadows, Nil by Mouth type stuff) Looking for the film look and I have a bunch of prime Canon L Series SLR lenses as Iam photographer. I have looked at the: Sony HVR-A1E £1702 Canon XHA1 £2573 and various 35mm adaptors (even the home made type). Problem is I only I have £1000 budget for a camera so Iam not sure HD can be done... So have considered a SD camera but these appear to be a DES at the moment. Cheap but soon to be in the loft along with the BetaMax, CD Player... Regards |
£1275 PAL Version Sony HVR-A1E from the USA...
35mm primes NOT "on a budget" approach
If you are on a budget and wish to do HD or HDV work, just leave your primes on your SLR body and use the lenses already optimized with these vidcams, FWIW.
Ok, but I thought there was no real control over DOF with these built in lenses? I though that was the purposes of DOF adaptors?
You can get the canon for 1800gbp if that helps you make your mind up ?
Hey Richard, have you ever consider a consumer level camcorder like the Canon HV20 and the Letus Mini? There's some good looking work done using the HV20.
I would second Andy's comments. There's some terrific work with the little camera and the prime lenses, that are only a bit out of your budget. Mike |
