-   Focus Enhancements FireStore (https://www.dvinfo.net/forum/focus-enhancements-firestore/)
-   -   Firestore for Canon XH (https://www.dvinfo.net/forum/focus-enhancements-firestore/88651-firestore-canon-xh.html)
James Jackson March 10th, 2007 06:56 PM
Which one do I buy for my A1?? Which one will have the most compatibility with the A1?
Doug Tessler March 10th, 2007 09:27 PM
yes I hace the FS-c 100 gig
The FS-C is the only one that Canon sells and recommends . I have it and it works great. The only downside is the battery life on the standard battery is not great .
Doug T
James Jackson March 10th, 2007 10:34 PM
Doug T
can it record 1080 24f and 30f and also SD 24f?
Doug Tessler March 11th, 2007 02:09 AM
yes and no
They are working on a 30f update , but it does 60 and 24 f as of now . it will be able to do 30 f as soon as a software update is introduced .
Doug T
Gert Kracht March 11th, 2007 03:49 AM
I have a question about the Firewire devices. I noticed that de A1 has all it's connectors at the backside.
What sort of connector does the FS-C have ? Does it have an 90 degrees angle, so the wire goes up or down or does the wire go towards the user.
Why do I ask ? Well, I almost had a fatal collision with the firewire cable and because the 1394 is very small, I don't want to think what could have happend to it when it was hit the wrong way.
Same thing about the headphone and video connecor, but I think those are far more easy to get in an 90 degree angle.
Barry Richard March 11th, 2007 12:44 PM
an IDIOTIC place for those ports !!
Contrast where the Z1 has them.
Canon's design is inexplicable
Bill Busby March 11th, 2007 01:43 PM
I'll tell you what's idiotic... the physical design of firewire connectors alone :-\
Barry Richard March 11th, 2007 02:33 PM
true.
The 6 pin design is much more rugged.
The 4 pin should never been used for camcorders -- why hasn't anyone redesigned that 4 pin port ??
Apple is idiot on this one I think
Dan Wilder March 11th, 2007 07:27 PM
Definitely one of my pet peeves as well. Normally I would criticize use of a non-standard connector on a product but this is one case where I wish they would stuff the standards. Canon's placement of the ports on the A1 only makes matters worse.
-Dan
