Upgraded to 2.1 w/ DR-HD100 - problem
I've done the upgrade to 2.1 and can't get the unit to record w/ HD100. I'm sure I've got something set wrong.
I have the HD100 connected via Firewire to the DR-HD100 (to DV I/O). On the HD 100, I have set in OTHERS - 1394 REC TRIG to SYNCHRO, BACK SPACE (HDV) to P-1394. On the DR-HD100: In Set up, I have EXT CTL OFF (I've tried PAUSE to no avail) TC EXT TC non-Drop (I tried to change it to Drop - which is how the HD100 is set, but it won't let me.) In HD Format, I have Quicktime in HDD Mode - HD Recorder In Record - Normal I have the DISP set to 720/30P Control is JVC GY-HD Anything stick out? I'm pretty flustered. Thanks |
More details:
When the unit is turned on and connected, the upper left corner of the screen reads "J STOP". Shouldn't it be reading Pause? Also it reads 720/30p TC and doesn't list 24p, even when the HD100 is in 24p. I get the feeling my camera isn't communicating with the device at all. In the HD Formats screen, it only lists M2T & Quicktime. Should it be also listing Quicktime 24P? On the set-up page, it reads v 2.1, so the upgrade obviously happened. Should I do it again? |
What happens when you start recording? |
Hi Bill,
You may want to give tech support a call. There is no known issues with the 2.1 upgrade, so maybe they can go through the settings again with you. Matt |
I have a problem with the 2.1 upgrade and the JVC HD 250. Now the DRHD100 crashes and restarts eachtime a rec trigger is sent from the camera. I think I'll flash back to 2.0
Shooting 720p30 |
Please note, the 2.0 and 2.1 upgrades are NOT compatible with the new JVC GY-HD200 and 250 cameras. The upgrade is for the GY-HD100/110 at this point. We are working on fixing the issue with the 200/250. I will report back here when we know more.
Matt |
Thanks for that info Matt,
I knew I had 2.0 working but it was with our other camera...the HD100. We are now using the HD250. I assumed it would work. But I went back to 2.0 and it also crashes the unit with the HD250. Is there any way to use in a workaround? |
Not with QuickTime at this point. We are working on this so hopefully we will have it resolved soon. I'll keep you updated.
Matt |
It doesn't do anything. It just stays in Stop. It will record manually, but won't bring the time code with it. I had this problem before the upgrade, but it was before I realized I had the wrong setting in the HD100. I'll check w/ Focus support, unless you can see something wrong w/ my settings above. Thanks. |
Double check that the HDV/DV switch on the camera is set to HDV mode. Make sure you are connected to the DV I/O port on DR-HD100. Do you see the J symbol in the top left corner of the DR-HD100 LCD? Your other settings look OK. If it still does not work, contact support.
Matt |
Yeah, I've double checked all those things. The J is consistently there, I've swapped Firewire cables (to the DV I/O port) to no avail, and the HDV switch on the camera is in the HDV mode. Would it make any sense to perform the upgrade again before I get a hold of support?
Thanks. |
You could try it, but I think your best bet would be to get tech support involved.
Matt |
| All times are GMT -6. The time now is 07:30 PM. |
