-   Focus Enhancements FireStore (https://www.dvinfo.net/forum/focus-enhancements-firestore/)
-   -   Recovering corrupted files on DR-HD100 (https://www.dvinfo.net/forum/focus-enhancements-firestore/498836-recovering-corrupted-files-dr-hd100.html)
Claude Mangold July 25th, 2011 05:06 AM
I have two corrupted files - when I try viewing it in QT i get "this is not a movie file".
Both files are the last files of the day on a docu shoot with GY-HD251- before powering the camera off - hard-disk on auto-off..
On the escond night the battery crashed at the end the documentary shoot.
Is there any known way to recover this file which is about 1.7 Gb ?
Jonas Hamilton July 26th, 2011 03:08 PM
Re: Recovering corrupted files on DR-HD100
#1 TRY REPAIR CLIP
--This may or may not work, but it's designed to re-wrap the end of a damaged file.
--I have had this work for me in the past when I lost power during a shoot.
#2 PLAYOUT CLIP BACK TO CAMERA
--Put camera in VCR mode and HIT REC
--Press PLAY on DR-HD100
--RECORD to TAPE the contents from the DR-HD100
--Once recorded to tape, PLAY THE TAPE
--PRESS RECORD on the DR-HD100 and record the contents of the tape.
Hope one or the other works for you.
Claude Mangold July 26th, 2011 11:51 PM
Thank you, Jonas, I'll try and post back !
Claude Mangold July 27th, 2011 03:31 PM
Method #2 worked - You saved my day.
btw -my files are HDV, according to the manual, #1 works only for DV, and the Focus customer support confirms this indirectly when I enquired today :
« Hello,
If the clips are playing back faultless, you could try to recapture the
video to your NLE program used DR-HD100 in playback mode.
I am sorry but there is nothing we could do more.
Best Regards »
So they are essentially suggesting your method #1.
many thanks, Jonas
Claude Mangold August 16th, 2011 08:05 AM
Having much trouble transferring back from tape to DR-HD100. These are long clips, like 7 or 9 minutes (but below the FAT32 limit). Inevitably, the unit either stops recording after 6-7 minutes, or goes to the end but shuts off abruptly when I press the stop button , generating corrupted files.
