-   Focus Enhancements FireStore (https://www.dvinfo.net/forum/focus-enhancements-firestore/)
-   -   Can You Help Me Build My Firestore System? (https://www.dvinfo.net/forum/focus-enhancements-firestore/105931-can-you-help-me-build-my-firestore-system.html)
Jordan Orberg October 18th, 2007 07:05 AM
Hello Everybody --
I'm ready to make the jump to a firestore, but I really want to make sure that I get the right equipment the first time around. First of all, I own 2 Canon XH-A1 cameras, and I edit my video on a Windows Based Premiere Pro CS3 system. I want to purchase one Firestore to make sure that its what I want to go with before I purchase the second.
I know that since I use a Canon Camera, I will need to go with the Firestore FS-C Portable DTE Recorder. (Correct Me If I'm Wrong) Found Here:
http://www.bhphotovideo.com/bnh/cont...arch&Q=*&bhs=t
I'm not sure which I want to go with because I'm not sure how much of a difference 100gigs vs 60gigs will give me. The extra 40gigs won't do me any good if the battery won't last long enough for me to get to record it.
Here's what I'm worried about -- Battery Life. Typically, I will shoot the corporate videos that I do in about 6-7 hours. (Not recording the whole time, but that's about how long the cameras are on) I want to be able to record for the full amount of space that is on the Firestore. Are there any kind of additional batteries that I can purchase or some kind of system that I can work out so I'm not constantly having to recharge these babies?
Any help would be appreciated! Thanks!
-Jordan
Bill Ravens October 18th, 2007 09:56 AM
I've been using 2 firestore FS4HD units for a couple of years with a Canon XL2 and a JVC HD110. I'm not happy with the firestore units. They're pretty flaky, dropouts, made cheaply.
So, I've upgraded to an Nnovia 120Gb unit. Check out its features. A lot more professionally made, a bit more expensive but worth every penny.
www.nnovia.com
Jordan Orberg October 19th, 2007 07:19 AM
Thanks for your help! Are there any kind of comparisons between the firestore and what you suggest?
Joe Matyas October 19th, 2007 07:32 AM
Try:
http://www.powerbagjunior.com
Bill Ravens October 19th, 2007 07:47 AM
No comparisons that I'm aware of. The Firestore is, fundamentally, just a hard drive. The nnovia unit is a complete recorder, playback device. It's much more robust. The hard drives are interchangeable, on some models. There's also an option for solid state memory instead of a hard drive. You can record directly onro the nnovia unit from an analog source. It's really a whole lot more reliable and flexible than the firestore. There's a few threads here at dvinfo on the nnovia unit. do a search.
K.C. Luke October 19th, 2007 07:24 PM
Well firestore still the best and easy to copy and paste into NLE system. The SONY DR60 only work on SONY or Vegas. Im not sure how was that be only "SONY". Battery Life get the 180mins with 2 set should last all the way on your Production shot. This is what my friend was doing.
Jordan Orberg October 21st, 2007 11:08 AM
What about portability -- is it as portable as the firestore? Any downsides to getting it instead of the firestore?
