Back to Firestore?
Hi,
question to all users: Is there a way to export/master any footage BACK to firestore? (e.g. use a P2 recorder as an I/O Box for a representation, fed by FS100) ULI |
As long as your video is in a file type that the FS supports, you can just drag and drop it onto the firestore from your computer. But keep on mind that the FS will only recognize a filename like the ones that it records, so you'll need to change it back to that. Depending on the length of the video (and file size), I wouldn't recomment going anything larger than 2gb because that is all that the Firestore will support. I would definitely say try it first and make sure you are successful with it before you actually show it.
