ENG drone
How does this sound.
A vertical only accent/decent drone that locks on to a pad laid on the ground by a news crew. Drone goes up to a preset altitude, and remains stationary, locked by GPS and laser or whatever on the target pad below. Camera on board has a zoom, beams down live video to the crew below. Short of a floating blimp camera drone, I think that is about as dumbed down a concept that is possible.......live truck operators are used to looking for direct vertical clearance already. :-) Paul |
Re: ENG drone
might as well just polecam it
Re: ENG drone
Why not just use a tethered blimp since it's a stationary shot? A blimp could stay afloat almost indefinitely, and wouldn't require andy battery changes, except for the camera or pan/tilt head. It's much safer too.
Re: ENG drone
Not sure how much safer a ballon is. The envelope for a balloon to be able to carry a 7-10Lb payload would be enormous probably more than 12 feet and the gas to fill it costs a small fortune.
Buoyant force for one m³ of helium in air is: 1 m3 * (1.292 - 0.178) kg/m3 * 9.8 N/kg = 10.9 N You could use a tethered MR that could carry that weight and could stay aloft as long as you kept it plugged into a generator or power. |
Re: ENG drone
see CyPhyWorks.com for a tethered drone.. thru the "microfilament" cable, you provide power and get an ethernet connection for command/control/video/etc.
Re: ENG drone
Unfortunately, looks like the FAA wants to only allow daylight drone use for news purposes, and you have to have a dedicated "pilot" for the operation. I wonder what "over people" means. If the people were clear of the vertical rise above the pad/tether, is that good enough I wonder?
Paul |
Re: ENG drone
In the UK we have a requirement for 30m clearance for take off and 50m once airborne (150m for > 7Kg). The only way to get below that is via a congested area safety case which as far as I know only one company has right now. If you are tethered then you have much more restricted controls over flight and if the drone is going to fight the tether then chances are it's going to come down at the extremes of the tether, i.e. how far it can pull away and against it horizontally. So how high the tether allows you to go could well be an important factor in deciding how much lateral clear space you need. Drones don't always come down vertically ;) |
Re: ENG drone
Perhaps the tether allows reclassifying the "drone" into a non-flying object and gets it out from under the burdensome FAA requirements. Or are they going to consider a pole cam as "flying"? Maybe the Ronin guys need to change their terminology for fear they will soon be regulated. Geez.
Re: ENG drone
There are tethered and moored classifications for balloons (Tethered vs. Moored Balloons). I once flew the Hooters balloon as a tether.
Re: ENG drone
Can we get a picture of the Hooters ballon? Were they always flown in "pairs" :-)
I wonder if a kite has classification under the FAA........it would seem less stable than a balloon. Paul |
Re: ENG drone
Ha Ha, great post, Jim. They should have been as unobtrusive with drones as they are with balloons. Here is the part of the reg from your post that deals with balloons.
Any balloon not designated to carry people is not regarded by FAA as an aircraft and is regulated under 14 CFR Part 101 only insofar as it might become a hazard or obstruction to flight. It must be more than six feet in diameter or have a gas capacity of more than 115 cubic feet, must be flown no higher than 500 feet above the ground and no less than 500 feet below the base of any cloud, must be flown no closer than five miles from the boundary of any airport, and must not be flown when the visibility is less than three miles. When operated between sunrise and sunset the balloon and its mooring lines must have colored pennants or streamers attached at 50 foot intervals beginning at 150 feet AGL and visible for at least one mile. When operated between sunset and sunrise the balloon and its mooring lines must be lighted to give a visual warning regardless of its altitude. Of course, they could have changed the "gas capacity" and size to reflect drone flight since most drones don't fly using lighter than air fuel. My point is, this is fairly non-intrusive, protects the public, and allows the FAA to concentrate on commercial and private aviation. |
Re: ENG drone
lol. I think it had their logo on it, that's about it. It was at a nighttime event during a balloon festival. Willie Nelson played.
There are 3 lifting gases of which helium is the only one in wide use in the USA. Hydrogen is used for gas ballooning outside the USA due to lack of access to helium and the cost. Hydrogen generates a lot of fear from folks due to the Hindenberg and its flammability, but there are safety measures used with it to lessen risk. Not sure you'd ever get insurance for a commercial application though. Ammonia has less lift than helium and hydrogen and is a poisonous gas, so probably not a practical choice either. I'm not aware of any recovery systems for helium so the cost of flying a system capable of substantial lift would be pretty high. |
Re: ENG drone
I actually wonder if one way forward may not be via a telescoping pole system. (As you see at some events for temporary area lighting purposes.) It obviously wouldn't have the flexibility of a drone (more limited height and fixed to one spot), but for some applications it may be all that's needed to get a better vantage point - see over walls, trees etc. And it would have some plus points - more stable and could carry a better payload (so maybe use longer lenses) and could be cabled, so no need for a link or batteries. Quite apart from the legal issues around drone flying in the first place. |
Re: ENG drone
I agree re hydrogen as a practical application, just think the insurance would be difficult. I may run it by my insurance guy the next time we talk. As I recall the envelope has to have conductors embedded in the skin to help bleed off static electricity.
If cold fusion doesn't work out there will probably be more interest in hydrogen as a lifting gas when the helium reserves are depleted. |
Re: ENG drone
1 Attachment(s)
| All times are GMT -6. The time now is 11:51 AM. |
