-   Flying Cameras (https://www.dvinfo.net/forum/flying-cameras/)
-   -   Trigger shutter release airborne RX100? (https://www.dvinfo.net/forum/flying-cameras/516586-trigger-shutter-release-airborne-rx100.html)
Bruce Dempsey May 16th, 2013 01:00 PM
How to trigger the shutter or take stills with the RX100 when it's airbore slung under a Phantom?
Video stays recording I assume but what about stills from an airborne RX100?
Bruce Dempsey May 19th, 2013 09:52 AM
Re: Trigger shutter release airborne RX100?
Read on another discussion venue where a fellow wraps a strip of plastic which has a bump glued and said bump depressess the shutter button and holds it down so that when the camera is in continuous mode, the shutter will fire at various rates until the apparatus is removed, In-elegant comes to mind but it should work In anything except Movie Mode in which the button needs to be depressed once for every frame
