-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Filming hdv straight to hard drive (https://www.dvinfo.net/forum/final-cut-suite/93683-filming-hdv-straight-hard-drive.html)
Daniel Stevenson May 9th, 2007 11:03 PM
Does anyone know if you can capture hdv footage straight from camera to the hard drive through firwire? i.e bypass the tape?
When I try in quicktime (through file:new movie recording) it only captures in dv even when ilink conv is off and vcr is in HDV. I am using the Sony HDV handycam (HDR-HC1E).
Can it be done in FCP? Or do I need specialist software?
Cheers
Daniel
Dylan Pank May 11th, 2007 08:07 AM
VirtualDVHS will do what you want. It's not particularly user friendly, there's no live preview, and it seems quite buggy. However it's free, and will record a pure m2t file to the HDD.
Download it from here. Be aware that this is a directly link not a page - the page is here: http://developer.apple.com/sdk/.
I think there's a new version of you sign up to the Apple Developer Connection but I don't know what the differences are.
You could get preview playback by starting to record to the HDD, then playing the file, as you record, in VLC. However there'll be a delay in playback, and I'd only recommend it on a fast computer on with a lot of RAM. plus it's fiddly.
Daniel Stevenson May 11th, 2007 06:07 PM
thanks dylan, i'll have a look. Will the m2t file be compatible with fcp?
Dylan Pank May 12th, 2007 02:44 AM
No, you'd have to use MPEG Streamclip to convert it.
Chuck Fadely May 13th, 2007 09:05 PM
I've done a good bit of "live" capture from a Canon at 1080i60 using Final Cut 5.1.2 into a Powerbook with an extenal 800fw drive.
The only issue is that it takes 15-30 seconds for the recording to actually begin after you've clicked "capture now".
I think maybe you need a tape in the camera to do it?
Chuck
Cheers
Daniel
Daniel Stevenson May 15th, 2007 11:43 PM
Thanks Chuck, what codec were you using?
Chuck Fadely May 16th, 2007 06:10 AM
My live capture was at 1080i60 and 30f into a 1080i60 project, set up using HDV 1080i60 Easy Setup.
David Garvin May 16th, 2007 03:09 PM
iMovie will do this.
James Miller May 17th, 2007 10:30 AM
I Movie captures HD in AIC format not HDV. This is what I have found.
To get the cleanest picture capture using VirtualDVHS convert the .m2t file in MPEG Streamclip to AIC or HDV, edit in FCP.
David Garvin May 17th, 2007 01:00 PM
This is correct, afaik. Is this an issue? IOW, do you prefer HDV to AIC?
James Miller May 17th, 2007 01:04 PM
I prefer AIC it's faster to work with when you do a lot of effects/colour in FCP. And converting .m2t to AIC seems a lot cleaner, However lets see what FCP2 has in store with Prores.
