Can my Powerbook handle HDV? HV20 better than DVC30?
I have a 15" 1.5 GHz G4 Powerbook with 1.25 GB of RAM and Final Cut Express 3.5. For storage I use two 150 GB external hard drives, one Firewire 800 and the other USB 2.0. My camera is a Panasonic AG-DVC30.
The DVC30's footage is okay, sometimes quite nice, but I'd like to try HDV, especially the HV20's 24p, which I once saw on a Panasonic DVX-100 and it made my jaw drop. I'd also like something a bit lighter. The DVC-30 quite hefty to carry around sometimes. Certainly can't take it hiking. Would my Powerbook handle HDV? Would the HV20 be worth selling my DVC30 for? The footage I've seen is certainly impressive. |
Nelson,
I've not tried to edit anything but.... My 1.67 G4 PB w/ 2 gigs can't play most of the transport streams samples that have been posted here without serious jitters or being jerky to the point of the videos being unwatchable. I'll be upgrading to a Macbook Pro after Apple's NAB conference in a couple of weeks. My suggestion is to download some of the samples posted on dvinfo and see how your machine handles them. Hopefully you will have better luck than I have with playback. Robert |
I've downloaded several of the clips here and my Powerbook also stutters badly, so thanks for letting me know that this isn't a good sign. Also thanks for the heads-up on the NAB. I might just upgrade, too. |
Hi Nelson,
I do some occasional editing on an older Dell notebook, a 1.7GHz celeron model. It plays the HDV streams flawlessly in a standalone player, but my NLE somehow uses more resources (less hard/software accelleration) and editing is virtually impossible. However, you can render the HDV(MPEG2 clips) to an intermediate codec that is easier to decode real time, but uses more disk space. I think I use the cineform codec. So it likely that, at the cost of some workflow and disk space, you can still use your trusty old hardware :) |
It’s a good thing some of you are holding off on getting an Apple until the NAB because they did announce a MacBook Pro during last years NAB.
I'll have to read up about codecs. Kind of a newbie here. As it is now, I'm getting more pinwheels than I'd like while the Powerbook crunches away. What HDV would do to it makes me nervous. |
I also think Robert is right: Quote:
http://file.meyersproduction.com/hv20/more%2060i.mov It played pretty well in Firefox. It hitched a little. The cat at the beginning was clear enough to make me take the Lord's name in vain, I must confess. It seemed I could reach out and pat the thing. Quite stunning. But did you mean that I should find some raw, uncompressed footage and try to import it into Final Cut Express HD to see if my system could handle it? If so, does anyone know where I could find some of this footage? |
Hi Nelson,
(been away a few days, don't know whether you're still onto this) as a matter of fact, I (we) meant: try to get hold of some unedited M2T files (straight off the camera, you should be able to find some around here), render ('translate') them to the cineform codec using Final Cut Express (I don't know that package so can't help you there), and try to put some of those resulting clips on a timeline. Then see what happens. It wil run much better than with the original M2T clips. So no, cineform is not raw, but still somewhat compressed, it holds a good balance between CPU-and-hard-drive-space-friendlyness... |
Hi Pieter,
I found some .mt2 files but can't figure out how to open them with Final Cut Express. However, I can open them with the VLC Media Player. Is this what you mean? The clip played full screen okay on my Powerbook but did show some jerkiness. I'll have to do some more research into how to open them (import?) them into FCE and then put them into a time line. To the woodshed I go... |
Hi Nelson,
those are certainly the files I mean, but if you can't open them with FCE I can't help you... I have no knowledge of that package whatsover (or hardly any knowlegde of operating one of those quite nice fruity computers, sorry) What i'd try 1st to get them to open: rename them to another extension like MP2, MPG, MPEG or something like that. But better ask someone else. And since we've moved to NLE/Mac, I'm off :)) |
Nelson,
FCE can't edit HDV natively like FCP can. FCE can only edit HDV if it's transcoded into AIC (Apple Intermediate Codec) first. -A |
Also remember that in terms of playback data rate, HDV is virtually identical to DV. If your system plays DV, it will play HDV.
Editing might be another story since there's more on the fly encoding/decoding going on - but for playback, they're essentially the same. |
No problem to edit HDV with a powerbook
Nelson I am editing HDV (SonyA1) with my powerbook 1.25 mgh and 3 external harddrives (from 120 to 320 gig) without any problem using FCP 5.
Michel |
I might still wait for the new MacBook Pros, I don't know. Then again, I don't know if I really need to go to HDV at all yet. Or if I do stay with DV, whether I should sell my AG-DVC30 for a VX2100. Or... |
| All times are GMT -6. The time now is 01:37 AM. |
