input XL H1 with Fire wire
I'm editing HDV material in Final Cut 5.1.4.
To make the capture in HD with fire wire from a XL H1, every thing is fine, but when I try to make the inverse way I have some problems. I can only pass the material to my camconder if this is in SD. if I try in HDV, I can only see one frame. For now its ok, because I still can monitor my edition in a canvas or a preview monitor, but I'll need put this film in a HDV tape. Had some one pass for this problem? Do you know if is a camcoder configuration in FCP? ('I still can't see a Fire Wire HDV output option in my software..) (editing in a FCP 5.1.4 , intel Xeon, with a DeckLink HD extreme card) |
Hi Rudimar.
Have you tried the option "edit to tape"? Are you trying to record your movie in the HD format (1980X1080)? If the aswer is "yes", I think is impossible to to that, since the HDV tape only accepts the 1440X1080 format or smaller formats. --------------------------------------- Oi Rudimar. Vc tentou a opçao "edit to tape?" Vc está tentando gravar seu filme no formato HD (1980X1080)? Se a resposta for "sim", eu acho que isso é impossível, já que a fita HDV só grava no formato 1440X1080 ou formatos menores. |
I've got the same problem, FCP doesn't output back to the XLH1. What are the alternative options?
Thanks |
Also can I output back from FCP to the camera through HD SDI?
Hi Chris,
No. You cannot output back to the camera tape using the HD-SDI. It is impossible to record true HD on that tape. That's why we call it HDV. The HDV format is 1440X1080 and 4:2:0. And the HD format is 1920X1080 and 4:2:2 or 4:4:4. Your best option is to output back to the tape using the 720p format. Good lucky. ;) |
FCP out to XLH1
So . . .it seems that copying a HDV/FCP timeline (1080i 29.97 YUV 1440 x 1080) is not possible. Is this correct?
If so, what are the options for going from the FCP timeline to the XLH1. Does the FCP timeline have to be in a SD Setup? What are the correct XLH1 settings? |
I believe it's "Print to Tape" in Final Cut, isn't it?
Thread moved from Canon XL to Non-Linear Editing on the Mac / FCP. SDI on the Canon XL H1 is an output only, not an input. |
So do you have to go out of an SD timeline?
