-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Capture Problem - I have tried everything! (https://www.dvinfo.net/forum/final-cut-suite/86882-capture-problem-i-have-tried-everything.html)
Tom Mikel February 19th, 2007 08:37 AM
Hi guys,
My problem is that I cannot Log and Capture with FCP 5.1.3 any material from my Canon XL2 (it's a new camera and hence a new problem). Final Cut shows me the Timecode and lets me remote control the deck but it won't give me any picture or sound. What I have tried and done so far is:
1. Safe Boot Procedure
2. Repaired the Permissions
3. Reinstalled the Quicktime
http://docs.info.apple.com/article.html?artnum=301852
4. Saved the FCP projects under different names (save as)
5. Created a new account and used FCP under that account
6. Tried all the different capture settings such as PAL, PAL basic etc (I'm in Europe)
7. Trashed FCP preferences
When I connect the Camera via Firewire to the DVD-player it works perfectly, so the FW connection is ok. Also, if I try to capture by using iMovie the same problem takes place: it shows me the timecode and lets me control the deck, but won'd give me picture or sound. Log and Capture fuctions perfectly when I use my Sony TRV950.
The equipment: Macbook Pro 2.16, Canon XL2, FCP 5.1.3, Mac OSX 10.4.8, Quicktime 7.1.3 pro.
So guys, help me out because I know you can!!!
Troy Teuscher February 21st, 2007 12:08 PM
Try Changing your Easy Setup
Tom, try changing your Easy Setup to Apple Intermediate Codec 1080i50. You'll have to manually que up the tape but it should capture.
Jonathan Jones February 21st, 2007 05:40 PM
This probably isn't your problem, but I just wanted to throw out a quick line to verify that you are in fact trying to capture while the camera is set to VTR mode?
-Jon
