-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Does anyone edit 30F using Final Cut? (https://www.dvinfo.net/forum/final-cut-suite/86662-does-anyone-edit-30f-using-final-cut.html)
Hugh Walton February 16th, 2007 08:18 AM
I have been searching and posting everywhere to find out if there is someone who definitively knows how to edit 30F footage in Final Cut. I have a Canon XH-A1 and am using Final Cut 5.1.2 to edit.
Please help,
Hugh
Jim Fields February 16th, 2007 12:30 PM
I shoot 720P 30 with my JVC, and edit it 720P 30. So yes I do, Whats your question?
Also keep in mind I dont do anything for broadcast, this is just for DVD, I do alot of weddings, and just prefer 30 fps
Chuck Fadely February 16th, 2007 05:06 PM
As you found (& state) in this thread: http://www.dvinfo.net/conf/showthrea...ight=final+30F
it works great on a 1080i60 timeline. What's the question?
Jim Fields February 16th, 2007 05:51 PM
What are you guys doing? recording in 720P 30 and importing it into a 1080i60 project timeline?
Poor mans upres?
Chuck Fadely February 16th, 2007 07:55 PM
The Canon XHA1 records 30F on a 1080i stream. You don't have to do anything special. I don't know how it works, but I guess it records the same thing on both upper and lower fields? In any case, it's beautiful -- just use HDV 1080i60 easy setup with sony firewire interface and capture. It just works.
Hugh Walton February 17th, 2007 08:36 AM
I have been trying to see if there are others, besides the two of us, on the forum editing 30F in Final Cut. I guess I was hoping some 30F guru would see the thread and post some amazing Final Cut configuration that we had not already tried. You have obviously found the correct work around and I will stop poking around. If it ain't broken don't fix it.
Thanks for your quick response and sharing your method.
Hugh
Chuck Fadely February 18th, 2007 07:57 PM
All's good. It's one of the few things about final cut and video that are Mac-like -- it just works! I was just stepping frame-by-frame through a downsized Quicktime .mov of some fast action I had shot recently at 30F. It's very nice. No wee ghosties or double vision.
