FireWire hub - good idea or not?
I tried to get a feel for whether FireWire hubs are a good idea for video editing or not. I got very mixed results from a search, but mostly in fairly old posts, so I am hoping for some feedback from more recent experience that you guys may have made.
My equipment includes an early 20" Intel iMac with two FireWire-400 ports, a Sony HDV camera, two FireWire harddrives, and a Tascam firewire mixer. To that, I will likely add another FireWire audio device for more audio outputs in the not too distant future. Right now, I always have the two external harddrives connected (the first one to the iMac, the second one to the other port of the first). The iMac's second port I use either for the mixer of the camera, depending on what I need at the time. To extend this setup (or make it more convenient), I can think of either chaining devices more (such as adding the mixer to the harddrive chain), or using a FireWire hub. I don't know much about this topic, but I expect that either approach may have some difficulties or things to consider. Any advise would be appreciated! - Martin |
Devices like video capturing, sound capturing, control surfaces, etc. will play up as soon as you put a firewire hub in line. I think a lot comes down to the individual device. Some will function fine on an externally powered hub, others will not. Check the documentation of the specific devices. I currently have four Lacie Firewire 400 Hard Drives daisy chained, with no issues so far. So maybe keep your hard drives on one firewire bus/point, and your audio gear on another. You could try putting a hub AFTER any gear that is incompadible with a hub.
Same with USB. Some devices work fine via a hub - others will not. For example, my ProTools M-Box will not work properly when you put it via a HUB. As you can't add any more Firewire ports on your iMac, I guess you'll just have to play around until you can get all your devices working... Hope this helps... |
Oh, and I ALWAYS keep my camera/deck on a SEPERATE firewire port for capturing.
Maybe a Firewire Switch (ie. so you can route specific firewire devices to you machine when you need them) is worth looking into? See: http://www.signvideo.com/firewire-switch-ieee-1394.htm |
| All times are GMT -6. The time now is 08:07 AM. |
