Colour correction in 5.1.2
Hi there
I'm an Avid editor with almost no experience on FCP and I'm considering turning to the dark side (!) for a particular project. I have FCP 4.5 running on a G4 we use for admin but before we rush out and buy a new Mac Pro I'd be grateful if someone can answer a couple of questions on the colour corrector in 5.1.2: 1. Is there a built-in gamma control that lets you edit in a curves interface rather than sliders? Maybe it was there before and I was just too stupid to find it. 2. How well does the secondary colour correction perform? Many thanks Tony |
1- No.
Nattress Film Effects has curves, although the interface is via sliders. nattress.com There is also Final Touch SD or HD (FT HD is a lot more expensive), which gives you color correction that is more powerful than FCP or Avid. XML/EDL workflow is a pain, although this may change. FT is updated often, and I think they are working with Apple on this. EDL into FT actually gives you the flexibility to re-capture, which XML doesn't. 2- The secondary CC in FCP: The quality is good. Performance-wise, it is real-time until you blur the mask. |
Thanks guys. I've checked out Color Finesse and I think that's the way to go because FT is off the budget radar. Lack of real-time playback isn't too much of an issue because I'm not under big time constraints on this project - rendering is an acceptable trade-off for the money saved over a Symphony Nitris!!!
