-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Delete not used stuff? (https://www.dvinfo.net/forum/final-cut-suite/77104-delete-not-used-stuff.html)
Niels Neeskens October 9th, 2006 03:25 AM
Hey everybody,
I made a dvd production and now I want to delete everything that I didn't use in the end to save space on my external hard drive. What is the best and more important the safest way to do this? Thank you in advance?
Niels
Richard Alvarez October 9th, 2006 06:13 AM
Niels,
It would help if you could tell us what NLE you are editing with.
In AVID, for instance, there is a function called 'consolidate' which will consolidate all the footage in a project, allowing you to eliminate the excess footage.
Niels Neeskens October 9th, 2006 06:18 AM
Hey Richard,
I am editing in Final Cut 5.1.2. , so maybe it is the same as in Avid. Thank you.
Niels
Cody Lucido October 9th, 2006 08:54 AM
Avid Schmavid
FCP has the same feature. It is called Media Manager and has lots of options.
Nate Schmidt October 9th, 2006 01:35 PM
Check out this article by Larry Jordan. http://www.larryjordan.biz/articles/...gr_delete.html
Niels Neeskens October 10th, 2006 08:56 AM
Thanx Nate, I had the same problems with it as described in the article, but now I know that I did the right thing.
Thanx mate
Niels
