Help! problem with DVD Studio Pro...
I'm barely functional in this program (using version 2) but I can muddle through, although this issue is stumping me and I have to burn this DVD ASAP.
I have a video clip that is set as the background of my main (and only) menu; the "in" and "out" points are properly set in the menu inspector, but when I check the project via the simulator, the video doesn't play, it holds the first frame as a still. I've tried different video and it does the same thing. Can't seem to find anything in the manual about this. Anyone? thanks, Charles |
In version 4 there is button near the viewer that toggles motion preview on/off. Also try burning a dvd image and play it with DVD Player to test it.
| All times are GMT -6. The time now is 12:44 AM. |
