capture question
I'll be filming with the XL2 in 16x9, 25p frame rate, 50i.
Should I capture dv PAL 48 kHz, or should I capture dv PAL 48kHz Anamorphic? Or maybe something else? Any suggestions on pulldown? Respectfully! |
It dosen't matter realy you can just put a check mark in the anomorphic column in the browser but you may as well just capture anamorphic and save yourself a step. IIRC you only need to worry about a pull-down when shooting 24p. Hope that helps!
| All times are GMT -6. The time now is 12:25 AM. |
