FCP 5 won't capture HD100u footage
I have a problem with capturing 720p30 footage from my JVC HD100. Every time a new shot comes up, capturing stops. Timecode on the original tape is continuous. Any ideas?
Bill,
Is your HD100 and "A" model? Did you record with TC switch in "REGEN" ???? Did you "unclick" Create new clip on start/stop in the "clip settings" tab of the log & capture window? |
capturing 720p 30fps
in your fcp settings, set it to "non Controllable device" intead of "firewire" or whatever. THen it will not quit during ithe middle of clips or drop outs.
hope this helps |
