-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Big Mistake (https://www.dvinfo.net/forum/final-cut-suite/71916-big-mistake.html)
Dennis Cummins July 20th, 2006 04:55 PM
Big Mistake
Gey guys badly need some help. i shot a football game recently with two camera's. problem is one of the camera was set to widescreen 16:9 and the other set to normal 4:3 now when i try put the footage together it looks all weird. any1 know what i can do? im using FCP 5. cheers.
Chris Barcellos July 20th, 2006 05:39 PM
Crop one in post to fit the other..
Bryon Akerman July 20th, 2006 07:34 PM
Crop the 4:3 to fit the 16:9. One, because you are doing sports footage, so probably a lot more horizontal action happening, but also because it looks cool.
Not too hard to do. Just use your motion control to pull it down to the action. If most of your clips are framed similar, adjust one clip, copy it, then paste motion attributes to the rest.
BRyon <><
Boyd Ostroff July 20th, 2006 08:31 PM
This thread might help: http://www.dvinfo.net/conf/showthread.php?t=71933
