-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Question about downconverting HDV to DV timeline (https://www.dvinfo.net/forum/final-cut-suite/71648-question-about-downconverting-hdv-dv-timeline.html)
Meryem Ersoz July 17th, 2006 12:14 PM
i have a bunch of previously captured HDV clips shot using the FX-1 which were captured using the AIC in iMovie. can i just drop these into an NTSC Anamorphic Final Cut Pro 5.1.1 timeline and render to use in an anamorphic DV project? or is there any point to re-capturing downconverted footage from the camera?
David Mintzer July 17th, 2006 12:28 PM
I dont know about FCP for I use Vegas. I have found that the quality is better when downconverting in Vegas---others have found the same.
William Hohauser July 17th, 2006 02:58 PM
That should work.
You might also try importing the clips into QuickTime Pro and converting to DV first. It will make editing easier as the files will not become un-rendered everytime you change them on the timeline.
Sam Jankis August 3rd, 2006 10:55 AM
Yes. I've used HDV from a Z1U to do just this.
