-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   sony hi8 camera to powerbook. . .how? (https://www.dvinfo.net/forum/final-cut-suite/71619-sony-hi8-camera-powerbook-how.html)
Chris Jonesy July 16th, 2006 10:26 PM
Does anyone know how to hook one of these dinosaurs up to my G4?
what sort of cable will I need?? or adaptor? or what????
help!!!
Chris Barcellos July 16th, 2006 11:09 PM
If you are limited to the Hi 8 cam, then you need a breakout box, or video card to import the footage to the edit on the system. Alternatively, get a hold of a Digital 8 Sony cam (depending on model) and you can play the Hi8 tapes on the Digital 8 and capture through fire wire.
Jonathan Bufkin July 17th, 2006 01:10 PM
Yeah the breakout boxes just converts the analog signal coming out of the camcorder via RCA cable to a digital signal for the editing software to use and sends it to the computer via firewire. Are you using iMovie to edit the footage?
Jon Bufkin
web.mac.com/bufdaddy
Boyd Ostroff July 17th, 2006 01:18 PM
Actually Hi-8 seems to be a popular topic recently. See the following:
http://www.dvinfo.net/conf/showthread.php?t=71225
http://www.dvinfo.net/conf/showthread.php?t=69736
Jason Hakala July 20th, 2006 12:11 PM
i used pyro dv to capture my hi8 video. although for some reason final cut pro would constantly quit, no matter what setting i changed, but imovie had no problem. so i captured in imovie and exported out to quicktime.
jason
