FCP5 and Soundtrack Pro Normalize vs Levels in FCP
I'm editing a video in FCP5 and the audio levels from the soundboard at dance recital are low and vary in loudness.
I need to normalize each section of the performance individually. So I'm going to use Sountrack Pro but I'm not used to the workflow. When I right click on the audio track and edit thought Soundtrack Pro it imports the entire clip (all 30 minutes of it) then its hard to find the area that the play head was at in FCP. Is there an easier way? I know I can adjust the levels in FCP using the pen tool but it seems like Normalize does a better job. Any help on the matter would be appreciated. |
Audio editors
Pete,
Soundtrack Pro is a multi-tracking editor with MIDI capabiliites. It's not optimized for altering the scope, EQ curve or other acoustic aspects of single pre-recorded tracks. The "normalize" function simply looks at the selected music and raises the entire track level so that the peaks don't go over the "digital zero" point and become overdriven. It will not raise the low-level information and make it "louder". What you want is a compellor, which is a compressor/limiter. This takes the entire selection and raises the low volume sections while limiting the highs. In effect it flattens out the difference between the lowest points and the peaks. Radio stations use this for broadcast music so that quiet passages in music are as easily heard as the loud ones. This is the functionality you want. The best audio editing software for this kind of work is either PEAK or DECK from Bias. Within PEAK is a plug-in called, "squeeze" which is the compellor functionality, but with a lot of control over how it does it's job. |
I'm sorry but this is not correct. Soundtrack Pro actually has two functions, in that it does do multitrack editing, but also does waveform editing and incorporates many, many audio processing functions. Some of them are taken straight from Logic Pro, Apple's high end audio software. The old 'Soundtrack' did not have all this functionality and was pretty much what you described. Soundtrack Pro is much more robust than its predecessor and can also make use of any plug-in available in AU format. This link, http://www.apple.com/finalcutstudio/soundtrackpro/ will give you a much better idea of the capabilities I am referring to. regards, -gb- |
-gb- |
i ended up using the my tried and tru method of alter the levels with the pen tool in FCP.
robert thx you put a name to the thing i want to do. i'll give it a try. btw, greg is also right soundtrackpro has grown into a more capable editor its not just for mixing multi tracks anymore. One thing I'd like to add is that I found soundtrack pro buggy and frustrating in how it integrates with FCP. I spent all this time making edits, when I saved it had an error and corrupted the clip, making me have recapture 30 minutes of footage and loose my edits. The second time I tried it the audio was muted in FCP. when i played the clip in the finder it was ok in the FCP browser but not in the timeline. Why not just drag it back into the timeline? Well I had done many edits that would have to be redone. Bottomline I found soundtrack pro good by itself but aweful as an interal audio editor with in FCP. |
Is there any reason why you didn't just use the compressor/limiter in Final Cut's Audio effects?
When I do recitals, I always get the original music played during the performance (usually a CD burned by the choreographer/instructor) and mix it into the audio along with the "house sound" (cheers, applause, etc.) I recorded with a mic. Then I can choose the levels of each during the edit to achieve a "live" sounding mix. I also record from the sound board, but only as a reference track. Like you, I have found that the levels coming from the sound board are not consistent.
Mike. |
Even if i had to do it over again I still liked 2 cameras because i could cover up my mistakes. but i did notice it added a lot of post production work (twice the footage to capture then having to sync them and pick which camera to show. since i'm inexperienced at dance recitals, it was hard to get close ups of all the kids while enticipating they eratic movement. friend in the business told me i just need to master a one camera shoot. |
Jay Rose has a good article on compression at dv.com:
http://dv.com/news/news_item.jhtml?L.../2004/rose0405 *registration required A compressor would be the most time-efficient way of tackling this problem... perhaps with a little manual mixing thrown in. |
| All times are GMT -6. The time now is 10:44 PM. |
