-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   16:9 clips in a 4:3 timeline back to 16:9 in FCP5? (https://www.dvinfo.net/forum/final-cut-suite/67444-16-9-clips-4-3-timeline-back-16-9-fcp5.html)
Joe Lotu May 15th, 2006 07:49 PM
I'm wondering if anyone could help me with a little issue.
I have a bunch of footage shot on an XL2 and I had to edit it in the standard 4:3 timeline so I could print the final project back to MiniDV tape for a presentation. It worked perfectly and letterboxed the 16:9 footage properly. Now that I have this long elaborate sequence edited and rendered in a 4:3 timeline, is there a way to get the sequence to work in a 16:9 timeline? I've tried simply selecting the anamorphic option and all it does is compress the already letterboxed footage rather than removing the letterbox. Thanks in advance.
Nate Schmidt May 15th, 2006 08:30 PM
Hi Joe, what I would do is copy and paste your entire edit into a new 16:9 sequence, then select all and right click remove attributes. The only thing that you want to remove is the distort property. This should scale everything correctly.
Boyd Ostroff May 16th, 2006 06:53 AM
I think Nate's solution should do the trick for you. But the next time you need to do something like this, edit everything in anamorphic 16:9 for starters. Then when you're finished with the edit, create a new 4:3 sequence and drop your 16:9 sequence into it. That will letterbox everything while still preserving your original widescreen version.
Joe Lotu May 16th, 2006 11:02 AM
Thanks for the tip, I tried doing something like that, but I changed the anamorphic properties for the sequence rather than the clips themselves. I'll try it when I get home.
I think I tried dropping a 16:9 sequence into a new 4:3 timeline before, but it just squeezed the image and didn't letterbox it. That's why I created I created everything for this one in a 4:3 timeline. But again, I didn't change the attribute for the clips themselves, so that must've been my problem.
Thanks again.
Hans Damkoehler June 5th, 2006 04:32 PM
With Graphics
Boyd, (or anyone)
Any thoughts on this:
I'll soon be editing a piece shot in native 16:9 DVCAM. The client wants the final presentation in 4:3 letterbox with pop up text in the letterboxed area. Now, when I import an anamorphic clip and drop it into a 4:3 timeline FCP seems to automatically adjust the distort function by 33.33% (effectively creating a letterboxed version in the sequence.)
Would you go ahead and edit the full piece in this manner OR do all the cutting in 16:9 then drop down to 4:3 for the addition of graphics? I'm afraid I'll need to go with 4:3 from the "getgo" because of the need to comp in graphics as I do the actual edit. 99.9% sure of that now that I type it.
Anyway, my MAIN question is: Is there any noticeable resolution drop by taking anamorphic 16:9 footage into a "distorted" 4:3 timeline.
Anything I'm missing here?
