-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Final Cut Pro 5 (FCP 5) Capture Question (https://www.dvinfo.net/forum/final-cut-suite/64133-final-cut-pro-5-fcp-5-capture-question.html)
David Nelson April 1st, 2006 11:19 AM
Hey everyone, I've had FCP 5 Studio for quite some time, never really had the time to learn much about it. I've joined www.lynda.com and got the full year premium subscription, WOW, it's great! But it doesn't answer the following.
I'm starting to capture video from my PD170. I did not shoot the footage in wide screen. The only clear way that the capture feature will show up is if I use anamorphic? When I capture using DV NTSC 48 kHz is shows up interlaced. When I use anamorphic it shows up non interlaced but streatched.
To describe what I am seeing in pictures please refer to the following link:
http://www.bigeyedeamedia.com/anamorphic.jpg
Please help! The video is due Monday and it's Saturday. I've done all the other editing in iMovie. Why did I choose now, because there isn't much left to edit, I just wanted to take advantage of FCPs awesome effects and settings. If not, I'll refer back to iMovie so that I can at least hit my dead line. Thanks in advance.
Boyd Ostroff April 1st, 2006 01:14 PM
Your PD-170 footage *is* interlaced. I think the reason you're seeing a less interlaced appearance in the anamorphic version is simply because you're blending the scan lines by squashing the image. But I don't think you can really judge from stills in the viewer/canvas - what does it look like on an external NTSC monitor?
If the interlaced look really bothers you then you could deinterlace with Joe's Filters, Nattress or DVfilm. But I don't think there's anything wrong with that still frame since it was shot interlaced and has fast movement.
David Nelson April 1st, 2006 01:22 PM
Good call. Since I'm new to FCP, I need to really judge the output not the input. Thanks for the info, but any futher info from anyone would also be appreicated.
Tim Commeijne April 2nd, 2006 03:08 AM
David,
This is normal. Your footage in the capture window is to show you where you are on your tape. It doesn't show it in full quality. Just capture it and then play it back in FCP. you will see there is nothing wrong with it. And ALLWAYS use a monitor, you'll see there is no problem with it.
