-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   24 Hd (https://www.dvinfo.net/forum/final-cut-suite/62592-24-hd.html)
Nitin Sawant March 11th, 2006 08:59 AM
24 Hd
I am totally frustrated with the 24 HD scenario.
1) Is there any solution to capture 24 HD?
2) I tried a few market solutions the latest being the Batch conform in Cinema Tools - Apple
3) After using the method described to use (2), the audio and video length are not the same and that is a total nightmare.
Anybody has any workable solutions.........
Please advise urgently as I am so messed up at the moment with so alomost 50 hours of tape shot in 24 HD waiting for my attention.
Nitin
Tim Dashwood March 11th, 2006 09:07 AM
My words from another post last week:
The word "native" should be included in discussions regarding HDV & NLE compatibility.
So, does FCP 5 edit HDV 720P30 natively? The answer is yes. It maintains timecode, you can use log and capture, it will batch capture, you can edit in native resolution, it will export and it works beautifully.
Does FCP 5 edit HDV 720P24 or 720P25 natively? Not yet, and potentially won't until version 6. Officially (according to JVC documentation,) FCP's 720P24 support will come in the next "maintenance release."
Does FCP 4.5 or 5 edit HDV 720P24 or 720P25 non-natively? Absolutely. There are at least three separate workflows that work quite well. We have discussed the various methods at length in this forum and in the HD100 forum.
The M.O.S. AIC method: (additional cost: $0)
If you have FCP5, you can set the Easy Setup to "HDV 720P30 Apple Intermediate Codec" and digitize, without TC, video in any JVC format.
You can also use iMovieHD to do exactly the same thing. THe AIC digitizer captures everything on the tape and makes a new clip every time it detects a new scene (start/stop.)
The AIC digitizer is not smart enough to know that the frame rate is set for 24 or 25, so instead it throws away the repeat flagged frames, but maintains a 59.94 fps frame rate for the quicktime file.
Therefore, 720P24 and 720P25 will require the use of Cinema Tools to conform the frame rate to 23.98 or 25 respectively. This method works well for M.O.S. projects like music videos, but is not ideal for sync sound situations unless you used a slate and want to capture the sound separately.
The HDVxDV method (additional cost: $80)
HDVxDV now supports 720P24 capture from the HD100. The interface is not as easy to use as FCP's built in Log & Capture because it has no live video/audio preview, and there are no search buttons, just FF, REW, STOP & PLAY.
However, it is simple and easy to understand. Brad Wright, the developer, has attempted to facilitate the capture of source TC, but it does not work well yet.
Simply put, you capture clips straight from the camera, then export them to a secondary codec of your choice for editing in FCP 4.5 or 5. I suggest Apple Intermediate Codec. There is one little inconvience in the software (v1.24) that creates 24fps files instead of 23.98fps files. Either one seems to work in a 23.98 sequence without rendering, so I guess it isn't a big deal, unless it is the root of the problem of sync issues some people have reported on long clips. If the sync issue is created during the export, then changing the frame rate to 23.98 in Cinema Tools won't fix it. Maybe Brad Wright can inform us of what is going on with regard to 23.98 vs 24fps.
The Lumiere HD method (additional cost: $179)
Lumiere HD now "supports" 720P24 and 720P25 capture. The interface is basically the same as HDVxDV (I believe both originated from Apple's DVHSCap) but Lumiere HD has added space for description, scene and take with auto-incrementation. The workflow can seem daunting at first (and definitely takes the most time overall) but there can be some distinct advantages for proxy offline editing.
However, TC is not captured and batch recapturing is not supported.
I have been testing the latest version of Lumiere HD (v1.6b6) for a couple of weeks and it is working MUCH BETTER than 1.6b2 ever did. The workflow remains unchanged, but you can output 720P24 back to the HD100. Lumiere HD 1.6b6 is the only piece of software on the mac that will allow you to do that.
Capturing HDV-SD60P or HDV-SD50P for "overcranked" slow motion. (additional cost: $0)
You can use Apple's DVHSCap (or HDVxDV/Lumiere HD) to capture 480P60 or 576P50 HDV to m2t files. Then you can use MPegStreamclip to convert and uprez the m2t streams to Quicktime. Cinema Tools can then conform the frame rate down to 23.98 and you have instant overcranked slow-mo for use in FCP 4.5 or 5.
Jon Glen March 11th, 2006 11:10 AM
this should be a sticky i'm thinking
