-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Compressor Cluster problems (https://www.dvinfo.net/forum/final-cut-suite/61203-compressor-cluster-problems.html)
Matthew Kent February 21st, 2006 12:06 PM
Hi...
I'm trying to run a cluster with the G5's at my school. I've been able to setup QMaster on each of the computers, and followed this tutorial to the T. When I start the cluster compression though, it sits for a little while, and then give me an NSexception error for each of the computers in the cluster, and at the end of the message, says there's no response from the node and it has timed out. I'll post the specific message when I get back into the lab.
Has anyone had any issues like this? Or does anyone know what I may have done wrong?
Any help would be greatly appreciated, I have lots of HD to process.
Tim Dashwood February 21st, 2006 12:16 PM
It is probably a firewall problem, but you should ask your question here:
http://discussions.apple.com/forum.jspa?forumID=954
Apple has a discussion board just for Qmaster.
