-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Modifying tracks in Batch Capture in FCP HD (https://www.dvinfo.net/forum/final-cut-suite/52517-modifying-tracks-batch-capture-fcp-hd.html)
Gabe Aluisy October 10th, 2005 08:37 AM
I had an assistant editor that specified the wrong audio tracks to import when they logged a project (used Right audio channel instead of Left). I primarily work on Avid where it is very easy to modify the tracks you want to import after the clips have been logged. I'm sure there is an easy way in FCP, just can't figure out where. Can anyone help? Thanks.
Shane Ross October 10th, 2005 10:01 PM
There is.
Delete the media. Scroll to the right in the bin with the clips until you get to the track assignments column. OPT-CLICK on the track assignment you want to change. A list pops up with several options.
Gabe Aluisy October 10th, 2005 10:54 PM
Thanks Shane
Thank you for the reply Shane. I knew it was simple. On my keyboard it was CTRL-OPT-click. Might have just been the setup. Thanks again.
