-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Very specific Pixel correction... (https://www.dvinfo.net/forum/final-cut-suite/52036-very-specific-pixel-correction.html)
Jeff Pryor September 30th, 2005 06:44 PM
After a recent shoot I noticed that the last 10 shots or so had a small, fixed position blemish, something on the lense I didn't catch apparently. It shows up a little lighter than whatever is around it, but is slightly transparent; enough so, that it gets somewhat lighter and darker as it passes over varying objects.
I use FCP, and have isolated the offending pixels (which number 6-8 in the canvas window when blown up to 800%) with a garbage matte. I've tried a simple brightness contrast adjust, and also 3 way color correction to lower the whites and mid until it matched darkness with an onscreen object. The thing is, when the shot moves and something brighter appears over the pixels they stand out as too dark. I am unable to find a perfect balance or even a satisfactory "happy medium". Anyone have an idea on adjustments/filters I might try? I could go through and keyframe all the shots and adjust as needed, but I thought perhaps someone might have an idea to save me a few hours of tedious work...
Thanks for the time.
Zach Mull October 3rd, 2005 12:20 AM
If the blemish changes brightness relative to the rest of the shot then you will almost certainly have to keyframe it. But just in case, I find that Gaussian blurs often work wonders in all kinds of situations. It's always worth a try to experiment with those, and if you can't get the shape/area just right for the blur with a garbage matte then you can try making a mask in Photoshop or Illustrator and using it as an alpha channel travel matte. Or you can try just feathering the edges of the garbage matte.
Brad Richmond October 10th, 2005 09:23 PM
Try the Digital Heaven plug-in "Reincarnation". You can find it on their website at:
http://www.digital-heaven.co.uk/indexflash.htm
Click on "Final Cut Plug-ins" then click "DH-Reincarnation" and watch the tutorial to see if this is what you need. I have bought and used DH-Box, DH-Dropout, and DH-Subtitle and they all work great. The best part is that each program is only $10 bucks!
I am not affiliated with Digital Heaven in any way other than being a satisfied customer.
I hope this helps.
