-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCP7 to compressor for blu-ray authoring with adobe encore (https://www.dvinfo.net/forum/final-cut-suite/508031-fcp7-compressor-blu-ray-authoring-adobe-encore.html)
Thanushan Kanagaratnam May 25th, 2012 06:38 AM
Hey.
I used the following workflow from compressor to export my video into encore cs5 for blu-ray authoring.
http://www.adobe.com/solutions/profe...e_with_fcp.pdf
When i import my video into encore. its telling me that its untranscoded under blu-ray transcode status.
Anyone had any luck with FCP to encore for blu-ray without spending a whole lot of time re-transcoding in encore. I know i should have tested a small clip before i transcoded 2 hours of footage.
thanks in advance for your support guys!!!
Thanushan Kanagaratnam May 25th, 2012 01:19 PM
Re: FCP7 to compressor for blu-ray authoring with adobe encore
i think this might be the problem why encore needs to re-transcode. I was on 30p and it doesn't support. I will try 24P and let you all know.
thanks
Here are the Encore-supported Blu-ray formats:
Frame Size/Display Aspect Ratio/Frame Rate/Scanning Method
720 × 480 4x3 29.97 Interlaced
720 × 480 16x9 29.97 Interlaced
720 × 576 4x3 25,00 Interlaced
720 × 576 16x9 25.00 Interlaced
1280 × 720 16x9 23.976 Progressive
1280 × 720 16x9 50.00 Progressive
1280 × 720 16x9 59.94 Progressive
1440 × 1080 16x9 23.976 Progressive
1440 × 1080 16x9 25.00 Interlaced
1440 × 1080 16x9 29.97 Interlaced
1920 × 1080 16x9 29.97 Interlaced
1920 × 1080 16x9 25.00 Interlaced
1920 × 1080 16x9 23.976 Progressive
Ronan Fournier May 27th, 2012 03:44 AM
Hi!
Personnaly, I ask a render in native format to FCP. Then I compress the .mov file in "H264 for Blu-ray" format with Adobe Media Encoder, then I import the .m4v and the .wave files in Encore which doesn't need to transcode them.
Indeed, I believe Encore is more confortable with files coming from Media Encoder than from Compressor.
Damian Heffernan May 27th, 2012 06:51 AM
are you telling me encore doesn't support 1920 X 1080p? I'll have to go and do a web search as I was hoping to do similar and go from FCP through compressor to encore. But my projects XDCAM EX 1080p.
Thanushan Kanagaratnam May 28th, 2012 09:10 AM
Ronan,
yea i tried that with a short clip and you are right. Encore likes Adobe Media Encoder file but it was too late for me. I let encore do its job and it re-transcoded everything again. It didn't take too long. Any quality lost when you go from FCP to Adobe Media Encoder?
Damian,
If you are shooting 1080 24P i don't think you will have any problem.
Damian Heffernan July 7th, 2012 06:24 PM
the pain is i shot in 25p
