FCP and external firewire hard drive
Since I'm relatively new to video I decide to place here my doubt so the pros could help out.
I have several external hard drives, but all connecting by USB, and they have been enough, since they are only used for backup. Now I need to buy a new one and my question is: Can FCP import directly into an external hard drive using firewire? If so, can the edit be done directly using the files in the hard drive or they need to be copied to the computer hard drive? Is there any lag in the edit or capture when using firewirwe? Is it possible to use connect the two devices (hard drive and computer) with two different firewire ports? I've got a mac pro with a 400 port and a macbook pro with a 800 port. Lets say that the external hard drive has only one of those firewire ports. Can I connect the two devices with a proper cable (400 in one side and 800 on the other)? Another thing. I've been reading and it seems that eSATA is the fastest connection between a hard drive and a computer. I have found a lot of external hard drives with eSATA connection. Is there any way to connect that, externally, to the computer, like using an adapter for fiwewire or something else. Thank in advance. Sorry for my english but I'm portuguese :-) |
Re: FCP and external firewire hard drive
All of my media goes to external drives via fw 400 or 800. I've used both laptops and mac pro w/FCP. I'm currently on v. 6. You'll be fine.
Thanks Jim.
I will have no problem editing directly from the external drive, then? Ohh, I'm on V.6 too |
Works fine for me. All media on external drive, scratch on external, only project file on internal drive.
Are these any good? Both haver USB, eSATA and firewire 400 and 800 ports.
LaCie - LaCie Hard Disk MAX Quadra LaCie - LaCie d2 Quadra Hard Disk I'm looking for 2TB drives. |
I only use G-Tech drives. They come formatted for Mac so plug & play. Go read reviews of external drives on Apple store website.
I've never had a LaCie DRIVE fail in 10 years, but I have had two LaCie power supplies crap out. $50 each to replace... NOT under warranty for some reason...
Also lost a WD MyBook external completely. Also like the G-Techs. I just don't own any right now. |
Speed matters. You will feel the difference between a slow drive and a fast one. Don't cheap out on a 5400RPM drive in a Firewire or eSata enclosure. For those, get a 7200rpm drive. External FW800 drives are not as fast as internals but noticably faster than FW400 and forget about USB. eSata external drives are noticably faster than FW800. YMMV
I use only gdrives for firewire and Caldigit for eSata. |
Not sure about the LaCie Hard Disk MAX Quadra, but definitely looking for 7200 rpm drive, and the LaCie d2 Quadra Hard Disk can deliver that.
Thank you all for your suggestions but I live in Portugal and G-Techs or Caldigit drives aren't easy to find around here. Les, do you work with mac or pc? How do you connect an external hard drive to the computer using eSATA? Never mind. Just found out. Need an eSATA card for the computer. What do you guys recommend. Firewire connection or eSata, bearing in mind that the objective is to import footage directly to the external drive and do the edit through there, with FCP. Or is USB3.0 the best option? Thanks |
Like you, I use FCP. I have used Firewire and eSata both to do what you describe. I have no experience with USB for hard drives and editing. Wouldn't touch it if I had the choice. YMMV
Tanks Les. Since you used both firewire and eSATA, have you ever noticed any difference in speed or any lag while transferring files or during the edit.
I mean, eSATA has the highest transfer rate, right? |
eSata is faster than Firewire, yes. It will be noticably faster than Firewire. Are you trying to capture from a Firewire camcorder to a firewire disk? If so, your capture will have to handle the ingest of data from your camcorder and output to hard disk simultaneously. There could be a performance problem depending on the model of your MacPro. I recommend searching here on DVInfo for "Mac Pro Firewire Capture external drive"
Thanks again Les. Did a search as you recommended but found nothing to clear my doubts.
The cameras have firewire ports (400) and I want to capture directly to a firewire drive (400 or 800). the mac pro is from middle 2008 (can put the specs her later). But if you think is worth it, and will increase speed considerably, I can install a eSATA card on the mac pro and connect the computer and the hard drive via eSATA. Something like this: http://www.lacie.com/us/products/product.htm?id=10331 What do you think? Does it worth it, or firewire is enough? Many thanks for your support |
for what it is worth, i've had a 1T Lacie big disk extreme fail. replaced the power and still dead. not funny.
but, as i work in Africa and power cuts are a problem, i have used the Lacie rugged FW 400/800 drives (250, 320, 500, 1T x2) with a Macbook pro and they are still going strong under hot and harsh conditions after some years. |
Now I'm getting worried Brian. A have been reading a lot of problems with Lacie drives, and it hasn't been easy to find other brands here (Portugal) with firewire (400 or 800) ports. A can find a lot with eSATA but firewire has been a problem.
Now I'm having second thoughts about the Lacie drives. |
| All times are GMT -6. The time now is 09:56 PM. |
