Audio out of sync using nested sequence. XDCAM35 1080p24
I am editing my first 24p video over 5 minutes long. Playing the exported quicktime file from a nested sequence, the audio drifts out of sync after 8 or so minutes . There is no drift if I export from the original sequence.
Thinking the timeline settings were off, I duplicated the original sequence, cleared out the new copy and then inserted the original sequence. The problem persists. I am using XDCAM 35 footage shot at 1080p24 with some small amounts of prores here and there. The sequence is frame rate 23.98. Anyone else seeing this? ANy ideas for a work around? |
| All times are GMT -6. The time now is 06:58 PM. |
