-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Simple audio editing questions in FCP6 (https://www.dvinfo.net/forum/final-cut-suite/476687-simple-audio-editing-questions-fcp6.html)
Geoffrey Cox April 12th, 2010 02:40 PM
Hi,
Couple of simple questions: I often like to work with audio separated from the image clip but I've come up against two issues with this in FCP6. 1) How do you drag a clip from the Browser to the timeline either as audio or video only (not both together as is normal)? Also I find when I do drag a clip to the timeline I have to link the mono audio files rather then them defaulting to this - how can I set the default to linked mono files? 2) In the timeline I often copy (alt) drag audio clips (not linked to their associated video clip) around the sequence but the only option that appears to be available is an insert edit which I generally don't want - I need an overwrite edit; it can be done by alt dragging to the canvas but you have to set the cursor at the correct edit in point first which is an extra step and a bit of a hassle. Is there a way to do this by simply alt dragging the audio in the timeline?
Thanks.
Chris Korrow April 12th, 2010 04:40 PM
Just went over this in a thread about layering 60 video clips without audio, Seem the way is to just simply lock the audio (or video) track to exclude one or the other.
If I'm working with a lot of video minus audio clips, (or lots of speed change clip etc.) I'll just set up a "working sequence" with the audio locked. Then I'll have all my clips in one tab ready to go.
Geoffrey Cox April 14th, 2010 02:04 AM
Thanks for the helpful info Chris. Seems like quite a blunt way of doing it though, but perhaps the only way...
Chris Korrow April 14th, 2010 07:37 AM
Yeah,
I just recently did a 20 second clip with 64 layered video clip with no audio and was trying to bring in just the video.
Felt it was quite hassle, but the reality was that it took most of a day to create, and maybe only 3-5 minutes to lock the tracks etc. to exclude the audio. So in the scheme of things it probably doesn't deserve a write for a dedicated command as it's only a matter of seconds per edit.
Geoffrey Cox April 14th, 2010 03:54 PM
Sounds like an interesting project your working on - 64 layers over 20 seconds - and I thought I was being daringly experimental with 3 or 4! Did FCP hold up OK?
Chris Korrow April 14th, 2010 07:23 PM
I got a new MP 2.93 quad, because my G5 was taking 5 + seconds just for an added clip to show up in the timeline, and that was only at about layer 16. The new machine really cranked through it till the layers in the 40's. It worked great, but to be honest, I thought it might do a bit better. Then again I am working some of the glitches out of the new system.
I'm upping the ram from 4>8 this week & hope that will help a bit.
I would typically do 5-8 layers with the G5 with no problem, but it would take forever to render. Still getting used to rendering on the new machine and think I'll have time to make some coffee, only to see "less than a minute remaining".
This project is a 30 minute doc for KET (PBS) on frost flowers, and has almost as many minutes of layered clips (4-64) as single.
As to the linked audio files, I'm still new to FC7 (from FC5) but isn't this just a capture setting issue? I've often forgotten to set the audio at capture,and it is a pain to have to do it manually for each clip.
Geoffrey Cox April 15th, 2010 01:25 PM
Sounds really interesting Chris - let me know if the doc is ever up on-line. Yes, good point about audio capture. Any thoughts on the timeline copy-drag only allowing insert edit issue?
Chris Korrow April 15th, 2010 07:57 PM
Sorry, can't help you there. I always place the playhead where I want it like you said. I'd hoped that someone else would chime in but...
Shaun Roemich April 18th, 2010 07:36 PM
Missed this - As you drag a clip to the timeline, there is a FAINT line through the middle of each layer. If you drag ABOVE the line the indicator shows an arrow indicating an INSERT edit; drag it BELOW the line and the indicators shows an OVERWRITE edit.
As well, for what it's worth, the shortcut for Lock All Audio Tracks is Shift - Apple - F5.
Geoffrey Cox April 19th, 2010 01:38 AM
Thanks for the info Shaun; unfortunately this doesn't work when dragging audio files or video files (linked or otherwise) *within* the timeline - copy (alt drag) only allows an insert edit and moving (drag), an overwrite. I can see the faint line you mention but it doesn't change the edit type depending on whether it is above or below it in this instance.
Shaun Roemich April 20th, 2010 11:11 PM
Interesting - obviously I never Alt-Drag because I drag clips around this way all the time. What if you double click on the clip in the timeline to load it into the Viewer and then drag the clip down from there, leaving the original iteration (that you "copied from") in place. THAT should work.
Erik Andersen April 21st, 2010 06:25 AM
In the sequence, click the two tabs labeled a1 and a2 at the left of the sequence. They are just to the right of the "mute" speaker icons. Then when you drag a clip from the viewer to the canvas only the video will be moved. Do the reverse if you want just the audio to move to the timeline.
Geoffrey Cox April 26th, 2010 01:51 PM
Eric - I've often wondered what those tabs do! Many thanks for the tip.
