-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Editing radio spots with FCP? (https://www.dvinfo.net/forum/final-cut-suite/43407-editing-radio-spots-fcp.html)
C. Byrne April 22nd, 2005 12:28 PM
I work for an ad agency and we're justing starting to get into tv production. I'm on a G5 2.0 w/ 1GB RAM and am using FCPHD. Now they want me to edit some radio spots. I'd be using FCP to edit the audio and exporting the audio file and converting it to MP3 to send to the radio stations. We don't have money in the budget to buy an audio editing program so I'm wondering if FCP can be used for this purpose in a barebones sort of way.
For the first spot I'm doing, I'll be recording the audio with my DVCAM camera and then importing it into FCP. But in the future I want to record audio straight to into my mac. I've seen some online articles saying I need a preamp or a mixer in order to bring the audio in. Buying a sound card isn't in the budget either. What is the difference between a preamp and a mixer and how would I set them up to feed into the mac. I'm assuming I can use the Voice Over tool in FCP to bring the audio in to edit.
Am I crazy or is this an option?!
Boyd Ostroff April 22nd, 2005 01:04 PM
Actually FCP shipped with an audio editing program - either "Peak DV" or "Peak LE" depending on your version. It's on a separate disk so it may not have been installed.
Matt Stahley April 22nd, 2005 01:30 PM
I like FCP as an audio editor after years of looking at small hardware sampler screens. But you may want to download Audacity. Its a free audio editing /recording app. Also allows plug ins etc. Very cool. I've used this myself for VO's etc. works really well with the Tascam US122 USB interface. Will also work with the Macs built in audio.I use this to convert vinyl to cd/mp3 too!
C. Byrne April 22nd, 2005 01:37 PM
Funny. Peak slipped through the cracks. I just installed it (Peak 3 Express). I guess you have to buy the full version upgrade. I'm going to check out Audacity now. Thanks.
So with these editing programs I still have the question of how to get the audio into my computer. Do I need a mixer or a preamp or both or none?
Glenn Chan April 22nd, 2005 02:27 PM
Mixers have preamps in them. On a budget, get a UB-series Behringer mixer because they have excellent preamps in them. They got into a patent infringement lawsuit with Mackie, which makes the Mackie mixers with VLZ-pro preamps which are also really good. Behringer mixers cost roughly a third of the Mackies.
To record VO, you need:
-a script or copy
-talent
-a room. Ideally, the room would have almost no reverb and no background noise.
-microphone
-cabling If you want to move the microphone into a quiet room (i.e. away from noisy things like your computer), get long cables.
-a mixer with headphone feed is nice but not required. Ideally the talent has headphones.
-preamp
-analog-digital converter (i.e. your camera, PCI/USB/firewire sound card)
-computer or other recorder
Some devices combine the preamp and analog-digital converter.
What camera are you using by the way? It may have a decent analog-digital converter in it.
Matt Stahley April 22nd, 2005 02:28 PM
Well to get decent quality you will want a pre and a interface for your mac. I use the Tascam US122 USB interface. its 2 channel line/mic with phantom power. Most will tell you to go for a firewire interface but honestly if you are on a tight budget and are only going to record a vocal track then usb should be fine. You can get several USB interfaces or under $200. there is also a new mic out that has a USB connection built in. I think its made by Samson IIRC.
C. Byrne April 22nd, 2005 02:41 PM
I've got a Sony DSR-250
