-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Two Lavalier mics for XL2 (https://www.dvinfo.net/forum/final-cut-suite/40050-two-lavalier-mics-xl2.html)
Bob Kaplan February 24th, 2005 09:58 AM
Rookie question/concern.
If I hook-up two lavalier mics for an interviewer and interviewee and have the standard 16 bit setting - it appears and sounds like the left mic is on CH 1 and the right is on CH 2. That said, when listening to the audio while recording the sound only comes in the corresponding ear. Can I adjust the audio later in a program like Final Cut to have stereo sound for each person miked up? Thanks.
Rob Lohman February 26th, 2005 04:55 AM
I'm not sure if FCP can do this (I'm PC based). But you need to
seperate the left and right channel into individual tracks and
then promote these to stereo.
But why would you want to do that? Usually you mix multiple
mono signals (which are outputted to both channels when you
export to a stereo track).
Kevin Kocak February 26th, 2005 03:19 PM
FCP can handle it. Your audio will come in as mono but you ca ndouble it up and create a stereo pair.
