-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   MPEG2 to DVD without quality loss (https://www.dvinfo.net/forum/final-cut-suite/386209-mpeg2-dvd-without-quality-loss.html)
John Majoris September 11th, 2009 10:20 AM
Hi Folks,
We wound up going with the ChaseCam for our road video and the results are good. Now however we need to take that MPEG 2, edit, and burn to DVD with minimal loss of quality. iMovie (I can hear the snickers now!!) just isn't cutting it so does anyone have any suggestions? Right now this is a 1 time project so the budget is low.
John
William Hohauser September 11th, 2009 11:56 AM
What else do you have? Toast will make a very good DVD but the preset menus are lacking.
John Majoris September 11th, 2009 01:06 PM
Hi William,
We only have iDVD. I think that the issue that we are having is the conversion from MPEG 2 to MOV (so that iMovie can work with the files) is creating a quality loss.
John
William Hohauser September 11th, 2009 05:32 PM
Are you using MPEGStreamclip? If you are, make sure the quality slider is at 100%.
John Majoris September 14th, 2009 07:08 AM
Hi William,
Yes, we are. So far it comes the closest to the actual quality that we can find.
John
Noah Kadner September 14th, 2009 04:33 PM
Upgrade to DVD Studio Pro- that's the best way to get better control over quality.
Noah
William Hohauser September 14th, 2009 07:41 PM
Look with at the footage with VLC and see if the problem is with the original footage. I use MPEGStreamclip all the time and the resulting files are as close to the originals as you can expect. Near identical. Is the camera actually producing full resolution video files?
