HD in FCP to Beta SP - Please Help !!
If there are posts on this issue - please point me in the right direction. I am trying to help our producer solve a problem.
We are shooting HDV on the Canon XH-A1 , capture to FCP in HD , edit in HD. Then is where the issues may start. We are producing a show for broadcast TV which requires the footage be submitted in Beta SP. We don't have a Beta deck in-house. We are exporting the footage as a stand-alone movie to a dual layer DVD which we take to a local TV station & transfer to Beta SP. That being said - when the network broadcasts the footage - there has been a severe issue with a trailing image when there is movement of the camera, subject or graphics. I am not sure what format was sent to DVD on these episodes. The last show that aired was sent to DVD as an HD file. The trailing image issue was corrected - but the footage still doesn't seem quite right. Given the procedure we have to work with ( HDV-FCP->DVD >Beta SP ) , What settings would you recommend for producing the best quality result ?? Thanks in advance for your expert assistance. |
Thoughts on workflow
Realize first that down-conversion from HDV to 60i NTSC will require some knowledge of final outcome on your part.
First is aspect ratio - You must decide which is best: 1) Convert HDV to 16:9 Anamorphic SD 2) Convert HDV to 16:9 Letterbox SD 3) Convert HDV to 16:9 Center Cut Extract SD This should be based on what the network wants your format to be. Second, most post houses will want a format they can use. I assume you are talking about a dual layer data DVD and creating a QuickTime or other format. I'd recommend calling the post house / network and asking for a spec sheet. This will be something like this: FORMAT: QuickTime Pro-Res 422, 29.97 NTSC, Self Contained. ASPECT RATIO: 4x3 TITLES: TEXTLESS at end of sequence This info will be important to know what you'll have to deliver. Hope this helps, -C |
