Mac Pro video card GT 120 vs HD 4870
I'm getting ready to upgrade from my G5 Mac Pro to current model and I'm trying to decide between the GT 120 vs HD 4870. It comes standard with a NVIDIA GT 120 which is merely a rebranding of the 9500 GT model or for $200 more get the ATI Radeon HD 4870 512MB.
Since I don't do any fancy animation or color, I'm thinking the GT 120 should be enough although I'll be moving up to a 24" monitor with a second 19". I find it irritating spending $2,500 and finding it comes with a cheap low end $50 video card having to pay an additional $200 to get something state of the art. Maybe its because the high end cards consume a lot of power and generate lots of heat and aren't needed for video editing, still I think its a little greedy charging that much for a system and not putting in a video card to match. I could never figure out why Mac is always at least 2 years behind the video card curve. |
Just my opinion but I always get base everything from the mac store and upgrade with other vendors, like OWC has a nice selection of RAM upgrades that are markedly cheaper than apple.
As for Video Cards - You really don't need something fancy unless you are a gamer or plan on heavy VFX. Even the new FCP will be compatible with that base card you listed. If you want to upgrade in the future, newegg.com has Mac compatible video cards in addition to OWC- upgrading things like video cards, ram and HD's is super easy on these computers and paying top dollar at Apple seems like a waste to me. Hope this helps, -C |
Keep in mind that all FxPlug filters are rendered in the GPU, not the CPU so the more VRAM you have and higher-end GPU processors the less time these filters and effects will take to render. You'll also want the most VRAM you can get if you plan on multiple monitors.
Snow Leopard is also designed to leverage more GPU power and save CPU clock cycles for more base-level and app-critical tasks which will make things more stable and possibly even a tick faster. (Read up on things like Grand Central Dispatch, OpenCL and even the new Quicktime X). Paying Apple for plug-in components is never a good idea. Let them supply the CPU, power supply and mainboard and get everything else from OWC or other reliable, cost-effective vendors and save the extra buck-age for.... toys! (laughs) NOTE: Another "benefit" of Snow Leopard (depending on your perspective) is that native gamma will now be 2.2 rather than the current 1.8. That means things will be WYSIWYG in FCP canvas and then in Quicktime without having to use the "match Final Cut color" option in QT now. That should also take care of color dispartities between PC and Mac since native PC gamma is 2.2 (unless you're using older nVidia hardware for VFX). |
Search Results for PCi Express Video Mac Pro at MacSales.com There are other companies offering Mac Pro-compatible cards, they're just not nearly as plentiful as PC vendors. BareFeats usually has a few of their advertisers that carry Mac video accys. |
Both cards have 512mb of vram. Quote:
Nividia 285 is compatible with the New Mac Pro
http://www.barefeats.com/nehal11.html , but as far as performance it is hard to say since every test seem to be based on games rather than professional video, price is also a bit steep last time I checked. ATI released the 4890, which I can get much more than gamers tests on it! If anyone knows more, I'd love to know. |
Not that this will help anyone here but FYI:
There are WAY more cards that will work in your Mac Pro and drivers built (rebuilt) by the hackintosh community. It just takes some searching, patching [adding EFI Strings w/ OSX Tools specific to your card] and porting the power connector (albeit most won't like the porting part). You'd be surprise what cheapy, no-name china stuff works. -C |
