-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Lost harddisk, please help me...This is important. (https://www.dvinfo.net/forum/final-cut-suite/24048-lost-harddisk-please-help-me-important.html)
Christian Hede Madsen April 4th, 2004 03:26 AM
Please help me...This is important.
Hi Ewerybody.
I have a problem. I cant get one of my harddisks to open( the one with all my films and editing tools).
When I say "open" I mean that I cannot "see" it on the desktop.
My HD-A ignores my HD-B( which is an external Lacie 120gb disk).
It is really a problem because I have deadlines for productions and a documentary that needs to be cut...
I have disk-warrior, but ofcourse I cant make it work when my disk wont open...Then there is nothing to repair...
Please help me...
If this was too confusing please ask questions...I am a little frustrated and confused...
Chr
Cannon Pearson April 4th, 2004 06:46 AM
What system are you running?
Have you tried the HD on another computer?
Have you checked the cables or tried new ones?
Boyd Ostroff April 4th, 2004 07:40 AM
Disk Warrior will scan for drives connected to your system even if they don't appear on the desktop. I have repaired a damaged drive that wouldn't mount this way. If it still isn't recognized try using a different cable and unplug any other firewire devices. Try plugging it into a different Mac and see if it works. Can you hear the disk spinning? Does it make any strange sounds? You could try removing the drive from the enclosure and swapping it into another enclosure, or possibly into an empty bay inside your computer. But don't attempt this unless you are confident in your ability to take stuff apart and put it back together again! You could end up doing even more damage.
If you do manage to get it working again I'd suggest getting another drive and copying everything over to it immediately.
If the drive itself is defective, there are companies that will rescue the data for you. I have used "DriveSavers" for this and they salvaged pretty much everything from an old 4 GB drive. They aren't cheap though, and I have no idea how much it might cost to salvage large DV files. When I used them they charged per GB saved.
Good luck, I hope it's just a passing glitch!
Christian Hede Madsen April 4th, 2004 08:59 AM
My systen is the OSX 10.2.8...
I will try with different cables tomorrow...I hope it helps...
Yes i can hear the disk spinning and trying to plug the disk into other Mac-computers is a good idea, but unfortunately there is no one else with a Mac in my town...
They are all PC users....
But thanks for the help...I really apreciate it...
Chr
Cannon Pearson April 4th, 2004 11:23 AM
Have you tried the usual maintenance procedures like repairing permissions and zapping the pram?
Patricia Kim April 4th, 2004 02:30 PM
Hopefully Jeff will come online to help you out. I have only one small suggestion if you haven't tried it yet. Shut your Mac down completely and restart. Sometimes various ports seem to lose their way and restarting fires them back up again. (Happened to me yesterday with my mp3 player attached. I was transferring files from iTunes and suddenly it wouldn't work. Everything looked fine, the player showed up as a drive on my desktop and said it was connected by USB cable. No file transfers possible, though. Disconnected, then reconnected and restarted the player. Worked fine.)
Ted Springer April 4th, 2004 03:33 PM
Your firewire port could be dead.... either the one on your Mac or the one on your Firewire drive. I've seen that happen often. You could try taking the drive out of the firewire enclosure and mounting it internally.
Josh Brusin April 4th, 2004 04:25 PM
try rebooting the drive while it's plugged in, try starting it up and then plugging it in...
Under the apple logo there's the about this mac item and then a "more info" button. With the drive plugged in and on it should appear in the "devices and volumes" tab and a firewire option. If nothing appears connected than it may be a cable issue.
If it isn't mountable (you get the initialize/eject option) try the software below. I haven't used it but it looks appropriate.
http://www.prosoftengineering.com/
the free demo will identify recoverable items...
Good Luck! (((don't initialize without getting your files first)))
Christian Hede Madsen April 10th, 2004 09:24 AM
I tried another cable today, but it did not work:(
I am really fustrated now...Can anyone give me step by step guidance to what I could do?
The disk is starting and ewerything, but it is just ignored by my other hard-disk...
Hope you will help...
Chr
Christian Hede Madsen April 11th, 2004 01:29 AM
please help!
I have a doc. that is just waiting to be edited and a crew of fifty is waitng for another film...
I apreciate the help I have already got, but some of it doesnt make sense to me...so if you could you put it up, step by step...
thanks
Glenn Chan April 11th, 2004 02:17 AM
You could try mounting the hard drive internally. It shouldn't be hard to dismantle the firewire enclosure for your firewire drive (there is an ATA drive inside). Putting it back together may be hard.
Anyways, once you have the drive, make sure you watch out for ESD and read the instructions over at http://docs.info.apple.com/article.html?artnum=75312. Those should be instructions on how to install a hard drive.
Or you could also try Disk Warrior as others have suggested.
If not then you should probably try re-capturing your footage. Right click your clips and select reconnect. If you logged everything right FCP can recapture off your source tapes. Backup your FCP project file a few times (especially onto CD-R) in case you mess up.
You can also try a drive recovery service, but they are... expensive. About $500USD or so per recovery (that's not a very exact figure).
Don Berube April 11th, 2004 05:23 AM
Do you have AppleCare? If you do, you probably qualify for "in-home" service. Not sure if they do that in your area, but they do in the states. If you are having trouble understanding the suggestions laid forth before you so far, you should probably be a little more practive and bring your Mac and the drive to an authorized Apple repair facility.
http://applefn.infonow.net/bin/findN...AGE=DNK_DANISH
http://www.apple.com/dk/support/products/overview.html
If you have AppleCare (everybody should always buy at least 2 years of AppleCare) then it just might cost you next to nothing. Stop torturing yourself!
First Shut Down your Mac. Make sure that your alledged "dead" hard drive is connected to its' own FireWire port on the back of your Mac and not connected to the "Loop Out" of some other FireWire drive. This will be helpful in seeing if your Mac recognizes your alledged "dead" drive. Now, restart your Mac and:
1) Click on your Main Hard Drive, open the Applications (OS X) folder, click on "Utilities", click on APPLE SYSTEM PROFILER
2) Click on "Hardware" (left side menu), click on "FireWire"
3) Check to see if it shows that your FireWire drive is connected to the port you plugged into in the back. If it shows that some type of hard drive is connected, you are in luck. Proceed to open "DiskWarrior" to diagnose and resolve the issue.
NOTE: It does not make ANY sense to NOT store your disk repair utilities on a backup CD, complete with serial # written on the CD... You need to become a more responsible editor and follow workflow 'best practices' as far as backup and archiving goes - your filmmaking associates will appreciate you a lot more if you do so.
Alas, there is still hope for you. If you can access the web, download "DiskWarrior" from the Alsoft web site. If you did not write down your serial # (uggggh...) and if your deadline is close by, then re-purchase the program, write down the serial # and back off a copy of the program to CD - Chalk up the cost of re-purchasing as a lesson for you to be more proactive and responsible as an editor in the future. You need to realize that ALL hard drives ultimately fail, that is why you need to be proactive and mirror your important data to a backup drive and learn how to backup and archive properly. Right now you are in "reactive/ why me?" mode! Not good.
4) IF, while in Apple System Profiler, you do NOT see anything being shown as connected to your FireWire ports, then you most likely have a faulty FireWire interface on your external hard drive. Contact the LaCie Technical Support Team in Denmark at http://www.lacie.com/dk/support/request. If you happen to know who your local LaCie Regional Representative in your area is, then contact that person and ask for help. Worst case scenario: I would ask LaCie for permission to break the seal on your drive *under the understanding that you will be sending it in for service*. This will allow you to try one more diagnostic: (as Glenn Chan suggested) install the drive internally on one of the available internal IDE busses of your Mac. You'll need to look at the termination decal on the drive and follow the instructions on terminating the drive as a slave. (Do this with the Mac completely powered down, of course) If the drive does not show up on your desktop or via Apple System Profiler under your IDE bus, then you do indeed have a problem.
Since it sounds like you are a bit too unfamiliar with this kind of stuff - I recommend you bring your computer and drive to an authorized Apple repair facility and have your issues resolved professionally. That just may, in your case, end up being your quickest solution!
Good luck and do keep in touch and let us know how you make out,
- don
Christian Hede Madsen April 11th, 2004 07:13 AM
Thanks for the help...
I am 17years old and this is my first mac...But shure it was stupid not to do a backup... I will try your advice when I get home...thanks...
I will get back to you all...
Christian Hede Madsen April 11th, 2004 07:15 AM
I am not trying to be a brat and appoligize for me not being responsible or anything... I have just had to learn all I know about macs by myself because no one I know uses macs...
Don Berube April 11th, 2004 08:00 AM
Hello Christian,
I just would hate to see you learn the hard way the way many of us did a good 15 years ago when 1GB easily cost well over a thousand dollars. These days, hard drive storage is so cheap!
Keep us informed about your projects! I'm impressed that you are so committed to learning about filmmaking. Keep at it and you will realize your goals. Persistence is key. :o)
- don
Christian Hede Madsen April 12th, 2004 03:14 AM
Well´finally I got my HD too work... at least I thougt so.
When I opened Final Cut Pro and wanted to do a print to video it froze.
There was nothing to do and when I restarted it I had the same problem with my disk...it was lost...
Can I do something about my final cut problem?
chr
Christian Hede Madsen April 12th, 2004 03:16 AM
-and my HD...it is a bit annoying...
Josh Brusin April 12th, 2004 01:35 PM
when you have specific application issues a search on google is a great 1st step. If you're having a problem 99% of the time others have as well. Try searching for +"final cut" +"print to video" +freeze or +crash or +problem...
works for any other issues as well...
g'luck
Patricia Kim April 12th, 2004 02:27 PM
Try the Apple fora - apple/support/discussions - for possible insights. I'm tempted, based on no experience with FCP but with iMovie, to ask about how much disk space and memory you have on your internal hard drive, because that has always proven to be the main bottleneck re working with video editing - with the result that I tend to try to keep my system pretty clean and even disconnect speakers, turn off the internet connection, etc., while using A/V software. But that might not be the problem at all for you. Very frustrating, so I hope the Apple fora can help you out a bit.
Christian Hede Madsen April 13th, 2004 01:44 PM
I have 210GB so space is not a problem... thanks for the suggestion with the "apple-place"...I will try it...
Jim Quinlan April 14th, 2004 01:18 PM
This is a method someone told me about several years ago. I used it once on a HD of mine (on a PC) that was going bad. Put the drive in a freezer for an hour or so and then try it. In my case, it worked and I was able to get the critical data off that I needed.
Christian Hede Madsen April 14th, 2004 01:31 PM
Ok...I will maybe try this...Can you tell me why it should work?
Jim Quinlan April 14th, 2004 04:58 PM
Making the drive very cold will contract the surfaces and that can sometimes make a difference in the way the drive spins or reads the platters.
It's unconventional but sometimes can work.
Don Berube April 14th, 2004 05:36 PM
Waitaminute,,, I thought his hard drive had already 'froze' haw
Christian, would you mind telling us why you are not taking advantage of your LaCie warranty and contacting LaCie for assistance? Does placing your hard drive in a freezer really seem to be a more realistic solution to you than taking advantage of LaCie's Tech Support?
Hellooooo???
- don
Christian Hede Madsen April 15th, 2004 01:32 AM
Well, I got the disk a long time ago( about 2.5 years) and I dont have the warranty, i got the disk as a present; it just stood there...plugged in and all...But I will try to ask for the warranty...
...Also I live on a very small island with no data-shops so I just cant drop it off somewhere...but I will see...
get back to you....
Brian Pink April 15th, 2004 07:50 AM
i've been having problems lately with hard drive mechanisms that take heavy use. the drive will start making the clicking/grinding of death. christian, i'm not sure if you've heard any noises like this, but if you have, a drive recovery service is your only real bet. if you haven't, chances are good that one of the solutions listed above with allow you to access the drive.
mirror your data!!! i have learned this lesson the hard way.
