-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   DVD Studio Pro video bitrate to high? (https://www.dvinfo.net/forum/final-cut-suite/199878-dvd-studio-pro-video-bitrate-high.html)
Niels Neeskens April 15th, 2009 08:04 AM
I got a weird problem. I made some sequences in Final Cut and send them to compressor through a custom setting (MPEG 2 60 PAL 16/9 6.6/7.8 dual VBR motion best). I imported them in DVD Studio Pro and made a menu for it. But when I tried to burn the DVD it says only with one of the sequences that the video bit rate is too high. What am I doing wrong here?
Niels
Tim Dashwood April 15th, 2009 08:22 AM
Are your audio tracks AIF or AC3? The bit cap for DVD included ALL the tracks (subtitles, all audio & all video angles.)
William Hohauser April 15th, 2009 08:47 AM
I never go above 7.2 in Compressor when using VBR. Even with AC3 audio the VBR will spike too high and you'll get the bit rate error message in DVDSP. CBR can be safely set at a higher level, 8.5 for an hour of video is a good bet.
Niels Neeskens April 15th, 2009 09:34 AM
Audio tracks are .wav but that can't really be the problem because they are all .wav and they burn fine.
I tried lowering the bit rate in the custom setting, but it still said that the bit rate is too high. When I tried one of the settings of compressor itself with a lower bit rate it worked. But probably I am losing some quality with it.
William Hohauser April 15th, 2009 09:38 AM
.wav files can be as big as AIFF files.
Robert Lane April 15th, 2009 11:36 AM
4 Attachment(s)
Niels,
Assuming you're using Compressor 3 try these settings for both your video and audio. One exception: "Frame Rate" should be whatever your preferred output source is, it's not required to use the setting here for best results.
Audio should *always* be AC3 Dolby; WAV files take up too much space and don't always encode well into the DVD spec.
Martin Mayer April 15th, 2009 11:41 AM
That IS your problem, Niels.
.wav files are too big. They may "burn fine" but the resulting AV stream on the DVD is too high a data rate. The .wav files must be compressed (with Compressor) to AC3 (Dolby Digital) files - as those above have said.
Niels Neeskens April 16th, 2009 03:35 AM
That was it! I made AC3 of the audio and had no problems anymore. You guys are the best! Thanks a million.
Niels
