-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   FCP 4: Anamorphic Confusion (https://www.dvinfo.net/forum/final-cut-suite/15344-fcp-4-anamorphic-confusion.html)
Benjamin Harrison October 4th, 2003 06:20 PM
I have a big project that I am just starting to edit. I spent the last two days logging and capturing a ton of anamorphic DV from a huge stack of DV tapes to a 200 GB, 7200 RPM Western Digital HD with an 8 MB cache. I just now dropped a clip at random into the timeline and was chagrinned to discover that it begged rendering. The sequence is set to the exact same settings as the video I captured, so why this would be the case is beyond me. Is this just a trait of anamorphic video in FCP, or is there some setting I'm missing?
Ted Springer October 4th, 2003 06:28 PM
If your individual clips are set to "anamorphic", it will want to rerender them to make them letterboxed for 4:3 video. If you uncheck this and drop them to the time line, they will not need to be rendered. There is no need to ever set your Sequence to 16:9 Anamorphic, as that just squeezes the video in more. So make sure it is not checked either.
FCP4 loves to rerender the audio, I sometimes find, for no apparent reason. But that does not take long at all.
Benjamin Harrison October 4th, 2003 06:42 PM
But if I don't have the sequence set to anamorphic the video squishes to 4:3.
Boyd Ostroff October 4th, 2003 07:28 PM
Actually I work a lot with anamorphic 16:9 in FCP3. I always set the sequence to anamorphic 16:9. Generally it recognizes the clips if they were shot on my PDX-10 as 16:9. But sometimes I use clips that were processed with other software, or 3d animation which doesn't have the anamorphic flag set.
It's no problem though, select the clip in the browser and go to "Item properties" under the edit menu. Check the anamorphic box BEFORE you drop the clip in the timeline and all will be fine.
Well anyway, this is how it works on FCP3, no idea if they changed anything in FCP4.
Benjamin Harrison October 4th, 2003 08:17 PM
Yeah that's what I'm used to in FCP 3. It might be a bug in 4...
Benjamin Harrison October 5th, 2003 12:04 AM
I finally figured it out. The problem was that, while I had my sequence preset on the right setting, the sequence I was trying to put the video into was not set on anamorphic. I didn't realize each sequence had its own individual settings. I'm glad this is the case, though.
Boyd Ostroff October 5th, 2003 07:30 AM
Yeah, that happens to me all the time in FCP3 as well. I create a new sequence and forget to set it to anamorphic. You do this with the settings command from the sequence menu in FCP3.... did they change this in FCP4?
Ted, can you explain how the item properties dialog differs in FCP4? In FCP3 there's just a checkbox for anamorphic. What did you mean by "just click around with your mouse"?
I'm not in any real rush to upgrade to FCP4, but would be interested in everyone's real world comparisons. I have a new G4/1.25 single with 1.28 gb of RAM which I run under MacOS 9.2 for FCP3. Would I see any significant speed/capability improvements under OS X and FCP4? I also sometimes run FCP3 under OSX on a new 15" aluminum 1ghz powerbook.
Ted Springer October 5th, 2003 05:48 PM
(Note: For some reason I am unable to show images in the post itself, so you'll have to click on the hyperlinks instead to see them)
When you have a clip in the bin
http://12.151.50.47/webimages/fcppic1.jpg
and you right click it (or select Item Properties from the menu), you get three choices.
http://12.151.50.47/webimages/fcppic2.jpg
Select "Format" and you will get the following screen:
http://12.151.50.47/webimages/fcppic3.jpg
This screen just looks like an information screen, and not like you can actually change any settings on it. But you can. If you click around in the "Anamorphic" field, you can engage or disengage this setting for that particular clip.
Boyd Ostroff October 5th, 2003 06:11 PM
Thanks for posting the screenshots Ted; that is sort of strange. It's a little reminiscent of the render manager however where you click in a column to delete files (but at least they give you a hint there).
BTW, I love the idea of "DVinfo: the movie"! When can we expect this to hit the big screen? ;-)
Jeff Donald October 5th, 2003 07:31 PM
Boyd, wait for Panther (OS 10.3) to be released in the next few months. Then the G5's and FCP4 will be a killer system. If you're not going to be getting a G5 anytime soon then their is no rush, other than getting behind the learning curve on new products (FCP4, FCP5, etc.) I suspect that FCP5 will not run on OS 9.x.x.
Boyd Ostroff October 5th, 2003 07:52 PM
I thought that FCP4 wouldn't run on MacOS 9... does it? I'm content enough with FCP3 for the time being and I find it very stable. I was forced to plunge head first into OS X last week when my Titanium PowerBook died during the middle of a busy production week. I just didn't have time to get it fixed, and it was pushing 2 years old, so I rushed out and got a new aluminum 15" Powerbook 1ghz. Nice, fast machine... but I really liked the look and feel of the Titanium better. Oh well, that's "progress" I suppose.
So now I'm in the midst of updating all my applications to the OSX native versions. I was planning to delay this by a few months, but what the heck... I really like the idea of a native Unix operating system on the Mac with a command line interface available (being a unix hacker from way back :-). Have updated to the latest OS X version of FCP3 and it seems to run just fine on the powerbook.
I had been thinking about a G5 for next spring or summer, but with the unexpected expenditure on the new powerbook, plus a new G4/1.25ghz desktop... well, now I'm just not in a big rush to spend the money. I'll wait and see how the G5's shape up with the new OS, and look forward to hearing all about everyone elses' experiences!
Denis Murphy October 8th, 2003 05:51 PM
anamorphic
This is plain wrong. If you are working with anamorphic video, both your item properties (in FCP) and sequence settings need to be set to 16:9 anamorphic.
Double squeezes only exist when your settings are plain wrong.
Ted Springer October 8th, 2003 07:01 PM
It doesn't matter what the settings for the sequence or the clip itself is, you can always edit it. The settings don't need to be anything. For instance:
Leaving everything as 4:3, if I edit in anamorphic (my clips are not usually flagged as such upon import), I can just drag and drop on the timline, do my editing and be fine. The output to the firewire DA converter or camera is anamorphically squeezed. I can then export an anamorphic file for a 16:9 TV. I do this all the time with absolutely no ill effects whatsoever.
If I import a clip and I change the settings of the clip to 16:9 but the sequence is 4:3, then dropping the clip on the timeline will make it want to render to be letterboxed. I think this is where you said I was wrong. Try it.
If you set both the sequence and the clip to 16:9, you will get a proper aspect view of it in your timeline (Canvas) monitor on your Mac screen, but it will remain horizontally compressed (anamorphic) on your output monitor, unless you have it hooked up to a 16:9 monitor. This gives no advantage to the editing process vs 4:3 for both sequence and clip, as the only difference between the two is that the canvas monitor is the proper aspect ratio, but the firewire output to the monitor is still anamorphic both ways.
The double squeeze only happens if your sequence settings are 16:9, but your Item Properties are not.
Denis Murphy October 9th, 2003 02:33 AM
anamorphic
Fair enough Ted, I see where you are coming from.
I just don't see why you would want to work this way -- why not keep everything 16:9 and have the proper aspect ratio in your viewer and canvas?
With your method, everything is distorted on the computer screen, which can't be any help to the editing process.
What am I missing?if you have a 16:9 monitor for external display, why not keep everthing in 16:9? If you are forced to use a 4:3 external, it doesn't care what your sequence settings are anyway.
Either way, you still have to re-render for letterboxed versions.
Ted Springer October 9th, 2003 05:09 PM
It's no help, but it's no hindrance, either. I only use the canvas as a guide at best. Mostly I look at the output on a calibrated monitor. If someone is editing without a monitor, then the canvas becomes more important.
The easiest way I have found to letterbox is edit everything in anamorphic and when complete, export as a FCP Movie, reimport into a new sequence, and check the 16:9 box. That way I don't have to do that on each clip.
Denis Murphy October 10th, 2003 02:15 AM
anamorphic
Hi Ted,
Different strokes for different folks, I guess! Can't see why having wrong aspect ratios in viewer and canvas is not a hindrance, even when using a properly calibrated (and I assume 16:9 capable) external monitor. You still do a lot of fine tuning in the viewer and canvas windows, so it's got to be good to be seeing your footage correctly - esp as there is no advantage to not seeing it correctly!)
Ted Springer October 10th, 2003 05:02 PM
I really only use the windows to set in and out points and to do a quick check to see where I am on the timeline. Other uses for the canvas is the 3 way color corrector where you take the eyedropper to the canvas. When doing it that way having it anamorphically squeezed is actually an advantage since the clip takes up more "real estate" and my chances of clicking the eyedropper on the color I intend increases, since those areas are bigger. My monitor is only 1024x768. No Apple Cinema Displays here, unfortunately. However I'll try setting everything to 16:9 next time just to see if it enhances the way I work.
Also I am used to dealing with anamorphic images. I've cut a lot of film that has a 2.39 aspect ratio (compressed horizontally at 2x). It looks way skinnier than 16:9. I got used to that so regular anamorphic video doesn't bother me I guess. :)
Wendy Rubin October 28th, 2003 03:44 AM
Cropping 4:3 video into 16:9
Hi- I would like to have frame lines come up in my canvas for 16:9. I have a video that was shot 4:3, but will be cropped (by someone else) into 16:9, so I want to position the individual shots accordingly. My video has been squeezed and unsqueezed, ut I've never figured out how to just get some black lines as a guide. Suggestions?
Wendy
