Recommendations on Hardware To Edit HDV
Well, its time to purchase a new Mac turnkey system that will allow me to edit HDV....I have just about had it with the limitations I am running into with the PPC G5...It served me well when it came to editing DV...I have a $4200-$4500 budget..
1. Please recommend a MacPro configuration 2. Should I Get A Blackmagic Intensity Card or Should I get the HDLink monitoring device that turns my LCD for quality color monitoring?...I would need this for monitoring only since I bypass the step to capture footage since I have a Direct To Edit Hard drive 3. A good blu-ray burner....maybe for the future when Apple decides to have blu-ray support....God knows when that will be? I think thats all I need.....Any other suggestions would be appreciated. Thank you |
To be perfectly honest (and someone correct me if I'm wrong) FCP does not support the use of multiple cpu cores. For your money you could definitely get an 8-core mac pro, but unless you're working in compositing or 3d programs you should be able to keep your configuration slim.
If I were getting a Mac Pro JUST for editing HDV: Mac Pro w/single 3.2gHz Intel Xeon 4-core 4GB RAM 1x320gb SATA hdd GeForce 8800GT Applecare package total: $3198 I cannot make a recommendation between the intensity and the decklink, since I have never worked with dte disks and don't know all it entails. You'll probably want to upgrade to the intel version of FCS, which will put you around $3900 or so. you could probably pick up 3 or 4 SATA drives for $300, depending on capacity and speed. I would also recommend a hardware SATA RAID controller, but I don't know how Apple's card stacks up against some others. I also know some others are cheaper (I think Apple's is $800 or so). RAID isn't a necessity, but it sure is peace of mind for an editor. I'm assuming you already have a monitor, otherwise you're stretching your budget just for the tower, a 20" screen and FCS. I say add blu-ray down the road when there's market saturation to support it. I think the only half-decent workaround for mastering to blu-ray from a Mac right now is with Encore CS4. Between the burner and the Adobe suite you're looking at another $800-$1200. It ain't the best, but this will give you plenty for editing HDV and you can always add to it later. Chris |
Which G5 do you have? A dual processor G5 should work fine with HDV in most circumstances.
Once I get the new hardware, any recommendations on If I should edit HDV Natively or should I convert the Quicktime Files from the Direct To Edit device into something like ProRes or Uncompressed 10Bit |
I notice you said you were running FCP 5. I do not know if you can you use the ProRes codec with a version less than 6 or not, so that point may be moot. |
That's a great link for workflow! I just checked it out.
FCP _does_ use multiple CPU's. I won't say it uses them as well as it could / should, but it does work.
I had a dual 2.5G G5 and it worked fine with HDV, but the 2.0g is really a lot less of a machine for HDV. there is a significant different in what FCP will do between the two. bare minimum is 8G of ram in a machine these days. get 3rd party ram as apple is again a real rip off. skip the nvidia card and get either the stock ATI 2600, or look at the ATI 3780 as a upgrade. the ATI cards work better, and the 2600 is respectable if you need to save a few $. 2.8ghz 8core is the best bang for the buck. skip applecare, you're not buying a laptop. |
| All times are GMT -6. The time now is 04:26 PM. |
