Color Curves in FCP
When I USE to use Sony Vegas I would always add a color curve to make my videos "pop". I am now learning how to use FCP and I cannot seem to find where something similar is. Anyone know where that might be?
Thanks Here is a pic similar to what I'm talking about: http://docs.gimp.org/images/toolbox/tools-curves.png |
Graeme Nattress makes some EXCELLENT third party plug ins for Final Cut Pro. Great
prices and absolutely awesome customer service. Nattress If you click on his 'big box of tricks' tab, you will see a bunch of plug ins, his 'G curves' plug in will do what you want I think. |
Did you try this in Final Cut?
3-Way Color Corrector - Final Cut Help : Apple Final Cut Pro Tutorial |
Aric, I am not trying to so much "color correct" as I am trying to make the video pop with a color curve. Making an "S" curve this way really adds a lot to your video, especially videos that you put on the web that are compressed.
Photoshop has a similar color curve that I use to make photos pop. http://www.photoshopsupport.com/tuto...sing/4-rgb.jpg Here they just added a very slight curve and you can see how more colorful the video on the right is: http://www.pbcentral.com/columns/hil...pse6curves.jpg |
Have tried this RGB Contrast Plug-In by Dominik Seibold? It's a simple way to quickly make the video image "pop".
I did what he said:
http://www.dominik.ws/DominiksContrast.fxplug.zip Just extract that zip-file to your ~/Library/Plug-Ins/FxPlug folder. If that folder doesn't exist, create it. But I dont see it in my FCP effects. And actually I had to extract it to: My Startup HD/Library/Application Support/Final Cut Pro System Support/Plugins Anyone know what I am doing wrong? |
Do you see it in the Effects menu under Video Filters?
Guys, I was under the impression that though FCP doesn't have the color curves per se, you can accomplish the same thing by using the shadows/mids/highlights sliders on the three wheel color corrector. Same result, different route.
I got it workin Michale, but so far FCP crashes EVERY time I try to render his effect after I add it to the video. Seems to work for other people tho so maybe I am doing something wrong.
Josh, I will try that, thanks. |
You know what? I take it back. I think you can create an S-curve using those sliders, but a more sophisticated curve, with more points, would be impossible in FCP without an actual curve tool. Since an S curve could have 3 points (2 really--in Vegas I used to add one kinda near the top, add one kinda near the bottom, leave the middle alone), you can likely do it in FCP.
You should be able to do the simple s-curve with those sliders. An advantage FCP has over Vegas is the way the secondary color corrector works. Vegas has one, but if you create a mask with it, you'll see that the border of the mask is jagged, ugly and pixellated. At least in Vegas 6, the last one I used (sorry if they fixed this in 8 and I don't know it). In FCP, there's an option on the secondary CC to feather the mask edge, and a slider to change the amount. So now you can do your crazy movie looks and not make your footage too monochrome in the process. For instance, tint everything in a scene a deep blue, but use secondary CC to correct the skin tones back to normal.
You can have grain issues in any NLE tweaking footage too much. |
Mike, I just started learning color, I was looking for an easy way to make web videos pop that's all.
Color seems great, once I learn it I am sure I can do what I am looking for with it. |
