-   Final Cut Suite (https://www.dvinfo.net/forum/final-cut-suite/)
-   -   Working with Time Lapse Stills (https://www.dvinfo.net/forum/final-cut-suite/127673-working-time-lapse-stills.html)
Steve Lewis August 8th, 2008 04:51 PM
So,
I have been doing some time lapse photography and dragging the stills from the dslr camera into FCP as a numbered sequence, with each still lasting 1 frame. One weird thing is that when I drag the stills (about 460) into my ProRes422 timeline, the first 150 are render-status green and the rest are red (in need of render). My question is why would some be "previewable" and some not?
Mike Hanlon August 8th, 2008 06:36 PM
I have a similar problem when I import a bunch of stills as animation (like from the original jump backs) in a DV timeline. I think it has to do with a cache the FCP keeps for stills. I tried adjusting the cache, but I just made it worse.
My solution is to export the timeline as a movie and import it back.
Tim Dashwood August 8th, 2008 06:55 PM
The best way to handle timelapse stills is to use Quicktime Player Pro and "Open Image Sequence."
Then just save it as a quicktime (the original format and frame size will be maintained) and just drag into FCP.
Steve Lewis August 8th, 2008 07:01 PM
I'll use QT Pro in the future....
In the mean time, I tried one today (there were no clouds so it isnt very interesting) and the sky came out all patchy and blotchy: www.vimeo.com/1494210
Why does it look like that? It looks good in FCP...
-Steve
Liam Hall August 10th, 2008 07:11 AM
-Steve
Those blotches are compression artifacts.
Steve Lewis August 11th, 2008 02:54 AM
Thanks Liam,
Is there a way I can get around that? Increase the bitrate maybe?
-Steve
Matias Baridon August 11th, 2008 10:18 AM
-Steve
How did you shoot that Time Lapse? Did you use still pictures? Did you make each picture 1 frame long??
Liam Hall August 12th, 2008 04:25 AM
Originally Posted by Steve Lewis (Post 919080)
Thanks Liam,
-Steve
Yes, you could try a higher bit rate. You can upload quite large file sizes to Vimeo, so don't hold back. You could also try a different codec though,
all codecs that use GOPs suffer to some degree from this time of problem, just look at a fade to black on a DVD.
Have a look at my minireel on Vimeo, I used the H264 codec at about 70% quality;
http://www.vimeo.com/1297303
There are quite a few timelapse shots on it and you'll see you can get rid of that banding.
