FCP level frame?
I have a few clips that are tilted and need to be leveled. What is the best option in FCP to perform this option?
Go to the Motion tab, and use the rotation.
Motion Guides
You can always send those clips to Motion, go into the view menu, show rulers. Then pull out guides from the rulers and set them on a particular horizon point as reference, then rotate the image in the properties tab using the guides as reference.
*e |
Thanks Bill that is easy.
Eric good to know Motion handles it the same as Photoshop. |
| All times are GMT -6. The time now is 01:40 AM. |
